Thought Exercise: Submini Circlotron OTL Amp - diyAudio
Old 8th January 2013, 06:50 AM   #1
Default Thought Exercise: Submini Circlotron OTL Amp
Hi Everyone!
I was doing some research into tube amps, when I noticed a trend among the fancy Ciclotron amps. Their enjoyment was severely hampered by their heat output (http://www.klausmobile.narod.ru/proj...1_mamont_e.htm)! So I started thinking, but couldn't come up with an answer, as I am still trying to grasp the basics of the Circlotron itself.
Is an OTL Circlotron built using sub-miniature tubes a worthy experiment? I assume it is much more involved than swapping out the monstrous 6AS7s with submini dual triodes and adjusting resistor values, but where to start?
Old 8th January 2013, 09:09 AM   #2
What are you trying to achieve? The heat dissipation in an OTL is determined by the output power and output power is determined by the available output current. Any OTL with subminiature tubes would necessarily give very low output power or you would need a very large number of them in parallel which is impracticle.
An example: If you want to get 25W in 8 ohm you have to deliver 2.5A peak and the average current from the power supply would be 0.8A, this is not possible to achieve with subminiature tubes.
My new Circlotron OTL tube power Amp. Dimitris AR Tubes / Valves 104 19th March 2014 09:06 PM
6C33 OTL Circlotron fdpa Tubes / Valves 2 30th August 2011 03:20 PM
Designing an OTL / Circlotron Dr Croubie Tubes / Valves 32 4th July 2010 07:48 PM
6S19 Circlotron (OTL) Fuling Tubes / Valves 62 13th November 2008 12:16 PM
Hybrid OTL Circlotron idea revintage Tubes / Valves 85 3rd September 2008 01:06 AM
Copyright 1999-2017 diyAudio
