Preamp Grounding PCB
Old 8th January 2013, 03:11 AM   #1
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Default Preamp Grounding PCB
Hello,
I am building a preamp entirely on a PCB. I am considering 4 layers with a ground plane if I can get a good deal, but likely will use 2 layers with the ground layer on the bottom. The ground plane will be one huge copper pour that everything grounded runs to, as is typically found in most PCB designs. I never tried this, always star grounding. In my mind, since the copper pour is huge, it will keep potentials between grounds to a minimum. Am I right? Is this ground plane a good idea or am I asking for ground loop trouble somehow by doing this?
There will be no digital parts in this circuit, only analog.
Old 8th January 2013, 06:01 AM   #2
artosalo is offline artosalo  Finland
artosalo's Avatar
I have done RIAA amplifier with two layers PCB and grounded it from one point only ( to chassis). It is practically hum free.
The heater voltages are DC.
Old 8th January 2013, 09:18 AM   #3
DF96 is offline DF96  England
Try it. If it works, fine. If not, you will have to start cutting slots in the ground plane to make the currents go where you want them to.
Preamp Grounding PCBHide this!Advertise here!
PCB Hookup Wire Shield Grounding bburl Parts 1 18th March 2010 12:40 PM
Grounding for a DAC PCB cedus Digital Source 2 5th December 2006 07:20 PM
Preamp grounding nlinus Solid State 1 15th January 2004 07:21 PM
grounding on pcb designs FunkyStu Solid State 4 12th March 2003 05:00 PM
PCB Grounding scheme dexter Solid State 2 27th May 2001 02:48 PM
