EL95 Parallel Push Pull design - Page 6 - diyAudio
Old 26th March 2013, 11:48 PM   #51
Ketje is offline Ketje  Belgium
Ketje's Avatar
Originally Posted by peterfarrow View Post
Rethink---
Raa is anode to anode at 17.7 ratio to the speaker.
not 17.7 per side, so I reckon it probably isn't 48Watts after all....
Anyone want to throw a curve ball here and sort this out...
Yes,and there is also a swing of allmost 500V on both sides in opposite fase,that's 1kV between anodes.So ...
Mona
Old 26th March 2013, 11:54 PM   #52
Originally Posted by Ketje View Post
No,no,no!!
You get a swing of 249V on the anode already at 289V.That gives a swing from 289-249=40V to 289+249=538V,a total of 538-40=498V (same as 2x249).So far ok,but the same,in opposite direction on the other side,total swing over Raa 2x498=996V.Back to the sec.996/17.7=56.2V pk-pk ! That's (56.2/2)x0.7=19.6Vrms.Power on 8ohm, (19.6x19.6)/8=48W ,that's better .
With UL somewhat less.
So if everything else is ok the OPT doesn't have the right ratio.
Mona
If I understand correctly, you are finding a swing of 249V either side of a center tap at a fixed 289Vdc on one half of the primary, and the same swing on the other half of the primary, only 180 degrees out of phase. The common center tap remains at fixed a.c. potential of zero volts, thus the maximum Vp-p can only be 498V anywhere, not twice that value.
Old 26th March 2013, 11:57 PM   #53
Send a message via Skype™ to peterfarrow
Agreed, however swapping EL90s gives me 25Watts RMS straight out the box, which is 14.2vrms before clipping, this is doing my head in as that is not possible from the voltage numbers we just discussed... at 500v pk-pk
Old 27th March 2013, 12:03 AM   #54
However it glows blue and looks nice...
Old 28th March 2013, 05:13 PM   #55
Ok, here is the neartly finished prototype...
6005W (EL90 or 6AQ5W) Parallel push pull prototype - YouTube
300v regulated supply using 6AS7G tubes and OA3/OB3 reference tubes is ROCK steady even at 250mA output stage current draw...
very please..
thanks everyone!
Old 13th June 2013, 09:48 PM   #56
Well finally, traded up the EL90 (6AQ5) tubes for eight parallel push pull 6v6 tubes, got 42 Watts over 20Hz to 20KHz
I will start a new thread because I have some other questions...
Parallel 6V6 Prototype Amplifier - YouTube
Old 1st April 2015, 07:12 AM   #57
I am confused by thread was it EL95's or 6aq5's/EL90's ????
looking for EL95 data sheets in english ??
shouldnt 8 push pull 6v6s be 160 watts or so ?
or 80 stereo ? heck we bench tested my Mc Intosh MC75 at 225 watts but distortion rises up a bit . Need a source for the mc output transformers lol .....copy franks rube goldberg winder bill
Old 1st April 2015, 08:43 AM   #58
jazbo8's Avatar
This one is in multiple languages.
Old 1st April 2015, 07:26 PM   #59
thank you ever so much
KT88 Parallel Push Pull Xpersephone2 Tubes / Valves 67 16th September 2014 11:02 AM
Push-Pull vs Push-Pull-Parallel rsumperl Tubes / Valves 8 10th July 2012 06:34 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
Parallel Push Pull Drivers gingertube Tubes / Valves 14 13th May 2005 02:32 PM
parallel or push-pull vlljpior Tubes / Valves 1 6th December 2004 01:13 AM
Copyright 1999-2017 diyAudio
