Tube recomedations for my first tube amp
Old 7th January 2013, 03:26 PM   #1
ice963 is offline ice963  United States
Default Tube recomedations for my first tube amp
Just got my first tube amp its a Yaqin MS-88B. It uses 4 KT88's and 4 6SN7 tubes. I've got about 100 hrs on at this time and even though its better than the Krell solid state it replaced I'm sure replacing the cheep Chinese tube would make a big difference. I read some good reviews on the Gold Lion KT88 but the 6SN7's seem to be a bit harder to narrow down. I know there a alot of variations any advice would be appreciated. I use the amp to drive Magnaplanar MG 1.7 so I did give up some volume for sound quality but it was worth it . I have a budget of $500 - $ 600 range.
Old 7th January 2013, 03:59 PM   #2
Loren42 is offline Loren42  United States
I run Gold Lion KT88s and I am running a set of new-old stock Phillips ECG JAN 6SN7WGTA tubes in my amp I built.
It seems the better 6SN7 tubes are the old ones - at least that seems to be the consensus among some audiophiles.
At some point you get diminished returns on your tube investment if you stick with the Chinese amp. Other components such as the transformers, caps, and circuit topography offer more performance bang for the buck.
What that says is that you will probably want to build your own amp with better transformers and a solid schematic design to get the most out of those expensive tubes.
Old 7th January 2013, 07:22 PM   #3
CoolJazz is offline CoolJazz  Netherlands
I build an Aikido with 6SN7's.
First I had new production Tung-Sol's wich I liked alot, very clean and detailed. After that I changed them to 60's RCA's. The RCA's are a little less detailed and more 'tubey', laid-back, warm, however you want to call it. I like that kind of sound, so they are still in there
Old 7th January 2013, 07:29 PM   #4
I was going to use the Tung-Sols as well, but I heard there is some QC variation that made me a little skittish about purchasing them.
I honestly do not know the validity or the magnitude of that issue.
Old 7th January 2013, 07:40 PM   #5
Eli Duttman is offline Eli Duttman  United States
Buy from a reputable dealer, like Jim McShane, who burns tubes in and tests them thoroughly. The good guys don't ship shaky specimens.
Eli D.
Old 7th January 2013, 07:42 PM   #6
All I can say about them is that the ones I bought were and still are fine, construction also looks good.
Old 7th January 2013, 07:55 PM   #7
Thanks! I will be sure to source all the rest of my tubes through Jim.
Old 7th January 2013, 08:20 PM   #8
On Hiatus
SY's Avatar
Second Eli's comments.
I don't know about reliability, but a couple of EH 6SN7s that one of the members here sent me measured and performed extremely well, and cost a small fraction of what good NOS tubes do. Very favorable comparison to CV1988 and 5692.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th January 2013, 01:53 AM   #9
Thanks for the info and recomendation. I'll be placing an order with Mr McShane next week. His site says he's gone for the week.
Tube recomedations for my first tube ampHide this!Advertise here!
6n6p tube as output tube for small guitar amp moonbird Instruments and Amps 28 7th September 2011 04:28 AM
Simple Tube Mono Block Tube Amp Schematic jleaman Tubes / Valves 16 24th November 2009 08:42 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
