So I've checked the related posts suggested, nothing.
Is it possible to model the following in PSUD?
Yes. You have to edit or add the rectifier values for the particular valve you want to use. duncanamps.com :: View topic - Suggestion for PSUDII
Sorry, didn't notice the difference in Rlim at first.
Hi, the short answer would be no for the only reason that the format only stores one named rectifier against the bridge. If you used the Graetz bridge, you would need two types.An externally hosted image should be here but it was not working when we last tested it.
However.... You can simulate the effect of the Graetz bridge with PSUD2 by making a modified rectifier with a vfac parameter which is TWICE the normal value, and using an all tube bridge rectifier. This should get things pretty close.
An example of the 5AR4 modified for Graetz is at PSUD rectifier list
If you visit the link, you can download a new rectifier list.
_________________
Duncan Munro
