Bias voltage slower to come up
Old 6th January 2013, 09:11 PM   #1
CarlyBoy is offline CarlyBoy  Canada
Default Bias voltage slower to come up
So I've PSUed a (voltage doubler) bias supply and it ramps up to full voltage in ~2.5 seconds. The B+ comes up in ~0.5 seconds. Is this a concern when no signal is present?
Old 6th January 2013, 09:26 PM   #2
20to20 is offline 20to20  United States
20to20's Avatar
The bias voltage needs to be up before the tubes begin to conduct with B+. The signal presence is not an issue. If the heaters get the cathode going the tube conducts without bias voltage and you will get out of control current. Did you create a bias voltage design running off of secondary voltage after the rectifier instead of having the bias voltage generated from a seperate tranny winding?
Old 6th January 2013, 09:48 PM   #3
The B+ and bias voltages are being derived from two separate windings. Trouble is the bias voltage is requiring a doubler and I guess the caps are taking longer to charge. I may have to incorporate a delay for the B+.
Old 6th January 2013, 10:00 PM   #4
20to20's Avatar
Large filters?
If it comes up faster than the cathode heat, it may not matter. You could put in a small cathode resistor to monitor the current as the bias comes up. Depending on the tube it could take 5 seconds to even begin to conduct much.
Old 6th January 2013, 10:49 PM   #5
Originally Posted by 20to20 View Post
..If it comes up faster than the cathode heat, it may not matter..
Good point. I forgot my plan: B+ supply is full wave bridge followed by 6D22S followed by pi filter. (I forgot because I don't know how to model this in PSUD ..hmm, I sense another thread) I will test the 6D22S to see if it's 30 sec claimed warm-up is correct. If so, no worries.
Bias voltage slower to come upHide this!Advertise here!
would smaller, slower, 80 minute records be possible? AnimusDivinus Analogue Source 19 4th September 2011 09:43 PM
Speaker Workshop runs slower on faster cpu ? percy Multi-Way 6 16th June 2011 06:43 PM
Replaced clock, now music plays 1.7x slower yammy1688 Digital Source 8 20th March 2010 03:25 AM
Bias Voltage AmpBuilder225 Tubes / Valves 4 17th March 2009 11:27 AM
bias voltage vs bias current woodturner-fran Tubes / Valves 3 24th February 2007 11:24 PM
Copyright ©1999-2017 diyAudio
