gm70 driver tube tests - Page 7 - diyAudio
Old 24th January 2013, 10:06 AM   #61
pics of 6j9p (on top) and 6j9p-e
enzo
Old 25th January 2013, 11:54 PM   #62
6n6p, 6p15p and 6p1p tested tonigh.
I'm in the process of building another rig that will give greater neg bias voltages and greater Vin, these tubes are all a little low mu for my box so perhaps these figures can be improved on, the OP i'm sure can. anyhow as V in is limited to 2vrms at present i went for 34rms/100vp-p
6n6p
gain 16.6 Va 180 Ik 23ma Vgk -5.7 (my max) dist 0.63, down to 0.59% at 43ma (max of box)
6p1p
I seemed to get only 20vrms out with 2vrms in, sure the gain is meant to be greater?
Va180 Vgk-5.5 Ik43ma Vout 20vrms 0
.29%
Ignore all the hash over 5k, Both these tubes showed few harmonics, but these are not swinging 180-200v
The 6p15p measured x20 gain as expected, dist dropped with increasing Ik to lowest of 0.28% @34vrms Va175 Vgk -5.7 (max) and Ik 43(max)
Seems the 6n15p is probably the best of the bunch, but nothing here to challenge 6e5p/D3a/6j9p etc
enzo
Old 26th January 2013, 02:24 AM   #63
TonyTecson's Avatar
i read somewhere that the Russian 6j52 is an analogue of the D3a.....suggest you test it to verify....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 26th January 2013, 02:34 AM   #64
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Not exactly, but close enough.
The Devil is not so terrible as his math model is!
Old 26th January 2013, 07:41 AM   #65
Have already, good tube, quite a spread in the performance of the tubes I had. I,m using them in my 12av5 pp, they gave the lowest distortion in situe, though not by themselves. They are much more expensive than 6j9p, these seem to go for as little as $0.50.
Enzo
Old 26th January 2013, 08:01 AM   #66
TonyTecson's Avatar
i have very good experience with the 6j9, used it in a mullard 5-20 circuit in place of the ef86.......i am satisfied...
Old 26th January 2013, 04:46 PM   #67
I've ordered some 6j11p as Artosalo suggested, not heard much about these.
Anyone have any other suggestions of sleeper tubes or better known tubes i could look at?
12hg7
8077
11hm7
8608
are tubes that looked promising from Pete Milletts work.
Enzo
p.s thinking of selling my Quad 11's if anyone fancys a pair :-)
Old 26th January 2013, 06:56 PM   #68
Wavebourn's Avatar
Yes, 6J52P are frame grid tubes, require accuracy in assembly beyond Russian standards. :-)
Try also 6J49P.
6J5P also make nice very linear triodes. Also 6J4P, but they want lower currents.
Old 26th January 2013, 07:52 PM   #69
Thanks for that :-), they are on the list!
Old 26th January 2013, 10:50 PM   #70
FullRangeMan's Avatar
What about the 6N1P for input and the 6N6P for drive.??
The new Lampizator GM70 amp use these tubes for great effect.
I appreciated any input on these tubes(6n1P + 6N6P) for 6C33 and GM70.
OBS.: Both are Triodes what looks good.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
6C33C tube socket for GM70 tube?? gaborbela Tubes / Valves 9 17th June 2011 05:23 AM
New GM70 tube with problem FullRangeMan Tubes / Valves 9 17th June 2010 12:10 PM
Accuton ceramic driver tests? 844 Multi-Way 4 11th May 2010 09:43 PM
New 7"driver tests ucla88 Multi-Way 4 2nd February 2007 02:01 PM
Planar driver response tests. ashok Planars & Exotics 3 28th May 2003 12:41 AM
Copyright 1999-2017 diyAudio
