#31 | |
Gyrators are voltage controlled CCS which emulates the AC response of an inductor in AC without the property of storing energy. There is plenty of info in the forum about using gyrators as loads. Particularly they are very helpful to maintain the bias point despite valve age, as the gyrator will force the anode voltage despite variance in gm/ra. If used in mu-follower mode, the gyrator can complement the driver in an excellent driver for output stages (particularly in A2) as will provide minimum distortion (flat load line in AC) and if well designed all the current needed by the capacitive load (or low impedance load in A2). Send me a PM re the audio circle details. Re 4P1L as preamp: the best preamp I've ever built but is a bit tricky on the microphonics. Can result in a fantastic preamp if well implemented though. Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp) http://www.bartola.co.uk/valves/ |
#32 | |
Some people have used the 1N60 on gyrators but personally haven't faced that driving requirement myself. I can't see why an 1N60 cannot perform better than a valve in the mu-follower as its gm of 0.9S and 9 ohm of rds will be difficult to match by any valve A bit of sand is really helpful in this circuit. Just simulate it in SPICE and you will see the results by yourself...Cheers, Ale
#33 |
Of course, the easiest way around excessive grid current in the 833 is to crank up the voltage so you can operate in A1. Lots of options, especially for the daring...
#34 | |
I feel a good pre amp is a must with a two stage GM70 amp. http://www.pmillett.com/lowmu_preamp.htm .
My "Art" website http://home.comcast.net/~djnagle/site/ |
#35 |
as i remember the microphonics on my 4p1l's were mainly 2 or 3 resonanses around 1500-2000hz i've tried damping the tubes with limited success and am working on mounting all the gain stages on a highish mass rubber decoupled platform.
all this talk of gyrator drivers is tempting me to dig out my sv811-10's :-) my gm70 stereo chassis started out as an A2 push pull 811-10 monoblock! enzo |
#36 |
Everything is subjective but if you haven't tried DHT in filament bias (no nasty caps on the signal path that will add that veil to the sound) then you are missing a new world. I've built many preamps using several DHTs such as 01a, 10Y, 30, 30sp, cx112a, 71a, 46, 4P1L and famous 26....
Worth trying, a different experience. Just have a look at the 26 preamp thread and you will find out why there are so many out there using DHT preamps. Cheers Ale
#37 |
Hi DJN,
I think its worth considering a line amp that can swing 10-20v pk-pk with a 2 stage design as it could open up the options of driver tubes. One of the bonuses of diy afterall is not having to conform to industry dogma, and if the amp has a sensativity of 5vrms then you get better snr and less sensativity to hum etc I considered swapping the 6e5p driver and 4p1l line tubes around... Just remembered your using bi or tri amping so i guess that could make things a little more interesting :-) enzo Last edited by enzoastro; 7th January 2013 at 08:35 PM. |
#38 | |
I would be more inclined for a line stage providing the right impedance and current driving capability to drive your cables and input capacitance. That and its sound are more important than the gain factor. The gain can better be provided by a well design driver in the amp :-) Cheers, ale
#39 | |
you're right. The resonance peak is about 1.5kHz. Damping with the classic methods can be very effective but also starving the filaments at about 550mA gives a very good result for reducing the microphonics. The downside is that gm is reduced and rp is increased slightly. Not a big impact to the 1k6 in triode mode. cheers, Ale
#40 | |
I can't use filament bias because I'm running parafeed with an autoformer, and I return the autoformer ground to the cathode. Since autoformers have no DC tolerance, I can't have DC bias there. |
| 6C33C tube socket for GM70 tube?? | gaborbela | Tubes / Valves | 9 | 17th June 2011 05:23 AM |
| New GM70 tube with problem | FullRangeMan | Tubes / Valves | 9 | 17th June 2010 12:10 PM |
| Accuton ceramic driver tests? | 844 | Multi-Way | 4 | 11th May 2010 09:43 PM |
| New 7"driver tests | ucla88 | Multi-Way | 4 | 2nd February 2007 02:01 PM |
| Planar driver response tests. | ashok | Planars & Exotics | 3 | 28th May 2003 12:41 AM |
