#101 |
I meant 6j11p, had a look around and they seem to be the same thing. They are listed as an ef180 type and to me look very like a higher dissipation (4.9w) 6j9p, with higher heater current. The anodes look just like 6j9p-e's ie tanks! If thats the case they should be well worth looking at!
Enzo |
#102 |
diyAudio Moderator Emeritus
Indeed they are built like a tank. I've seen them listed as E280F equivalent also.
Verstuurd van mijn GT-N7000 met Tapatalk |
#103 |
I did try C3G triode as input/driver tube (gain about 42) to the interstage xformer but I did not like the sound, compressed, loss of dynamic, still not bad sounding for SE amp. With C3G (triode) as input and 6B4G as driver/interstage the sound is more powerful, more dynamic, the sound is satisfying.
Unison845 |
| 6C33C tube socket for GM70 tube?? | gaborbela | Tubes / Valves | 9 | 17th June 2011 05:23 AM |
| New GM70 tube with problem | FullRangeMan | Tubes / Valves | 9 | 17th June 2010 12:10 PM |
| Accuton ceramic driver tests? | 844 | Multi-Way | 4 | 11th May 2010 09:43 PM |
| New 7"driver tests | ucla88 | Multi-Way | 4 | 2nd February 2007 02:01 PM |
| Planar driver response tests. | ashok | Planars & Exotics | 3 | 28th May 2003 12:41 AM |
