300B Globe physical dimensions - diyAudio
Old 5th January 2013, 09:53 PM   #1
tomchr is offline tomchr  Canada
tomchr's Avatar
Default 300B Globe physical dimensions
I'm working on the chassis layout for my 300B amp. I plan to place the 300Bs relatively close to the OPTs, so getting the dimensions right seems worthwhile.
Does anybody know the dimensions of the globe bulb 300B versions, such as the Fullmusic 300B/n? I'm looking for the largest diameter of the bulb.
Thanks,
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 6th January 2013, 09:48 AM   #2
Dimensions on this page here Fullmusic Full Music TJ tubes specifications
Old 7th January 2013, 07:46 AM   #3
tomchr's Avatar
Sir. You rock. Thank you. For some reason when I searched, I only found the electrical specs, not the mechanical ones.
The globe is 65.5 mm in diameter at the widest part. The ST bulb is 61.5 mm (but I knew that from the JJ spec sheet).
~Tom
Old 8th January 2013, 08:26 PM   #4
My pleasure.
I have a pair of globe TJ300b's myself and my unscientific measuring method says that 65.5mm is about right!
WTB Globe 866's steve516 Swap Meet 0 9th May 2012 10:13 PM
6SN7-GTB Globe (Chinese) Layberinthius Tubes / Valves 6 16th September 2004 02:20 AM
TJ Music Mesh Globe 300B New Unused Matched Quartet mozfet Swap Meet 1 26th October 2002 06:41 PM
Tianjin 300b globe and meshplate... john Tubes / Valves 0 9th September 2001 08:31 PM
Copyright 1999-2017 diyAudio
