Tube mic preamp
Tube mic preamp
Old 14th November 2003, 09:23 AM   #1
borisgrand is offline borisgrand  France
Question Tube mic preamp
I have seen this schem on the web, but i've lost the original file (but i printed it, this is a scan) an where it was...!
- Is there anybody who know this schem ?
- How can I put a gain pot ao switch ?
Old 14th November 2003, 11:36 AM   #2
here's the link:
http://alterneo.free.fr/tubepre.GIF
Old 14th November 2003, 01:28 PM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
You could replace the 1M gridleak resistors at the input with a 500K stereo volpot.
A switch to do what?
If it's for source selection you can fit it at the inputs as well.
Frank
Old 14th November 2003, 01:44 PM   #4
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
it's nice..pretty simple...but the voltage used is pretty high...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 14th November 2003, 01:53 PM   #5
...really, not after the first 12AX7 ?
to switch the gain (ex: 6-12-18-24-... dB)
Old 14th November 2003, 02:08 PM   #6
rafafredd is offline rafafredd
Default I don┤t think so...
Transformerless? 12ax7 cathode follower? no.... it┤s not "nice" for a mic preamp. Use a transformer balanced circuit, like this one instead:
http://www.gyraf.dk/gy_pd/g9/g9pd.htm
Or, if you need to go transformersless, just use this one:
http://www.iclr-sch.com/results.aspx...%3fID=13749966
This one will give you a low impedance input!!!
Old 14th November 2003, 02:20 PM   #7
yeah, i know this one...
your 2nd link is dead...
Old 14th November 2003, 02:36 PM   #8
fdegrove's Avatar
If you're using a stepped attenuator, go for a series type.
By doing so you keep the load constant and you can put it where you like: in front of the first stage or inbetween the two stages.
6 dB steps are quite coarse but that's up to you.
Regarding the CF at the output, you can easily convert it to use a different tube or even opt for a WCF.
Frank
Old 14th November 2003, 03:45 PM   #9
Default second link again
Yes. This is dead.
This is the right one:
http://dogstar.dantimax.dk/tubestuf/graphics/shroom.gif
Tube mic preampHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 05:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 05:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 08:14 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 06:28 PM
Copyright ©1999-2017 diyAudio
