DHT SE amp with ultrapath - diyAudio
Old 3rd January 2013, 01:00 AM   #1
Default DHT SE amp with ultrapath
I did build 2E22 SE amp with AC filament (because I like AC for filament ). Sound is so sweet and warm. Hum is > 13mVac, so I can hear them at my chair.
I intend to take an ultrapath with a Capacitor between power tube's cathode to B+ in oder to get lower hum AC and lower gain. There are some ultrapath schemas on the internet, but the tube is auto bias. Mine is fixed bias .
So :
- How can I calculate the value of this capacitor ?
- 2 these capacitors will be connected to the same point, B+. Is it OK ?
Thanks and regards,
QA.
Old 3rd January 2013, 07:29 AM   #2
Vinylsavor's Avatar
Hi!
ultrapath can only be used for hum reduction with auto bias (cathode bias).
I would never use ujtrapath for that purpose though. I only use it to 'shorten' the signal path in te output loop.
I would rather find the cause of the hum and fix it
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 3rd January 2013, 01:54 PM   #3
Palustris's Avatar
DHP + 6.3V AC filament = > 13mVac hum
Old 3rd January 2013, 07:12 PM   #4
Ketje is offline Ketje  Belgium
Ketje's Avatar
AC for tubes is normal to indirectly heating cathodes.Direct heated cathodes needs DC to get rid of all the hum.On a PP the hum is commonmode and is cancelled in the OPT,but I suspect that even then you have to adjust the balance regularly.
Conclusion,use DC,
Mona
Old 3rd January 2013, 08:14 PM   #5
Palustris's Avatar
"AC for tubes is normal to indirectly heating cathodes."
That's OK for 2.5V filament but for a 6.3V tube you have to expect some hum.
Old 4th January 2013, 12:38 AM   #6
Have you tried winding a filament transformer with bifilar wound
3.15V windings, connect them in series and use them to power the
filament? Sensing resistor is soldered to the junction of the two windings.
I once did this with my 3C24 and there was no audible hum a foot
from my 12" fullranger.
As always, YMMV.
Reza
Old 4th January 2013, 02:13 AM   #7
As always, YMMV.
Reza
I use separate toroided transformer for 2E22 filament, so hum get a bit low. I will try CT transformer.
There are some ways of hum cancelation for DHT. I never try this way : http://www.dmitrynizh.com/dht-filament-hum-cancel.htm
all dht se PX4 disco Tubes / Valves 27 3rd February 2017 06:50 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
DHT SE auto bias circuit mogliaa Tubes / Valves 2 22nd July 2012 08:02 AM
Which way to choose: Comparisons Chip/Class D/SE DHT ? WE91 Chip Amps 21 18th May 2007 07:48 PM
DHT Ultrapath Linestage schematic help dsavitsk Tubes / Valves 6 15th January 2006 04:28 AM
Copyright 1999-2017 diyAudio
