Tube mic preamp problem - Page 2 - diyAudio
Old 4th January 2013, 03:31 AM   #11
gootee is offline gootee  United States
Are the Instrument inputs the ones that you called "Hi-Z", before?
Can you check to see if you can measure 48V between the center pin and one of the other pins, at each MIC input jack (with no MIC plugged in)?
Old 4th January 2013, 04:41 AM   #12
Instrument inputs are marked Hi-z on front panel. I will measure 48v right now.
I am confused about where to find 150V.
A tech told be today that it would bew the tubes. First thing I did was swap left to right tube and then swapped in a pair of other tubes.
Where does the mic get its gain?
Old 4th January 2013, 02:20 PM   #13
The schematic is definately incorrect. I managed to check for 48V. It is good. I left the probes in and switches off 48 Volt phantom. The voltage droppewd slowly as I expect to see with phantom circuit. Mine has only 8 1N4003 in total. I did not find the source of the 150 Volts but I was able to confirm that I have 160Volts at the plate switch.
I am at this point thinking of walking away and selling as is but rethinking that I bought this to learn about it, willing at the time to lose the money to gain experience.
I was wondering if I may feed the mic input with an MP3 player and begin tracing with an earphone or something like that. I do not have a signal tracer and have not done this before but this may be the time to learn patience and focus.
Old 5th January 2013, 01:58 AM   #14
Yeah, wow, just learning patience and focus could be worth thousands of dollars, in my case.
Regarding tracing with something going into the mic inputs: I am not an expert, actually. So I don't know what the typical mic output amplitude might be. A quick search might find it. But you could just use a speaker with a mic in front of it, too, with the mic plugged into your unit.
(Sorry. Today was a long day, for me.)
How to make mic input transformer 150:50KCT for mic tube preamp??? delipasha Tubes / Valves 9 3rd February 2012 05:54 AM
Noise problem with Mic Preamp..any help appreciated silentblackhat Solid State 11 20th November 2005 02:17 PM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 10:19 AM
Mic preamp problem kimarin Solid State 1 29th October 2004 09:11 PM
Tube mic preamp kimarin Tubes / Valves 5 23rd October 2004 09:30 AM
Copyright 1999-2017 diyAudio
