6N2, 6N6, 6N11 - Please help a beginner! (long) - Page 5 - diyAudio
Old 6th October 2013, 09:32 AM   #41
JonSnell Electronic's Avatar
I stock Russian made 6n3p-E (ECC42) and 6n1P (ECC88). Low noise double triodes of similar specification with pin 9 as a screen (not heater centre tap as in ECC83 etc).
Fairly inexpensive too!
Support for PMC DS-001, (Hypex) UcD400,Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 27th November 2013, 08:19 PM   #42
lduarte1973's Avatar
hi , is 6N1 - J chinese the same as 6N1P russian ?
Just because im getting bald doesnt mean i cant like hair metal
6N11+TDA7293 60W+60W Amplifiers fn9mm Chip Amps 5 28th August 2011 01:37 PM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 11:53 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 01:06 PM
A little help for the beginner? 959Turbo Multi-Way 3 10th January 2002 08:52 PM
Copyright 1999-2017 diyAudio
