| diyAudio Sponsor | ||
#11 |
my ecc99 are in a long tailed pair/direct coupled. Can i just reroute the heater and fire it up?
#12 | ||
diyAudio Senior Member
Ciao,
Frank |
#13 |
should be no problem, as the stage before it is coupled directly...
but, id be reaaaly happy if you'd want to elaborate on ecc99< or> than 6n6p. |
#14 |
Chinese 6N11 is more like Russian 6N23P-EV or western 6922/E88CC
Chinese 6N23 would be Russian 6N23P or western 6DJ8/ECC88 Chinese 6N1 is Russian 6N1P Chinese 6N2 is indeed Russian 6N2P or as quoted – a western 6AX7 (was there ever such tube?) Chinese 6N6 is Russian 6N6P - NO DIRECT Western substitute. Nevertheless quite good tube in right application. I think the Russian equivalents are easier to find than original Chinese tubes nowadays and as for 6N1/6N1P or 6N2/6N2P the Russian made have also these ruggerized EV versions available but Chinese don’t. |
#15 |
Guess that makes searching for subs easier!
The reason i keep askong about that 6n6p is that my circuit uses russian penthodes for output. I just like putting exotic things in my amp and would really like to experiment with different tubes. And i think it looks prettier too! ![]() i think i am going to do some ebaying |
#16 |
If you have trouble finding Russian 6N23P-EV, 6N2P-EV, 6N6P or even 6N1P-EV (sometimes depending on circuit it could replace 6N23P-EV and even sound better) for good prices, drop me a mail.
#17 |
Hello,
does somebody have tried 2 x 6n6p in parallel (4 triodes) ? I would like to test a grounded cathode preamplifier with 2 6n6p (4 triodes) in parallel by channel. For one channel I think of 2x 6n6p (4 triodes) in parallel, B+ 270V, one Ra=1K7, one Rk=60 ohms for a total of 80mA Seems to be ok with TubeCad. Opinions ? Best Regards Pascal |
#18 | |
#20 |
Hello,
finally, I have made some changes and my preamp is finished. Valve (5Z3) PSU 270V, Ra=750, RK=100. The 4 6n6p are in parallel with 12K input resistor and each valve has his own RK/CK. Operating point 200V/20mA Great sound Pascal |
| 6N11+TDA7293 60W+60W Amplifiers | fn9mm | Chip Amps | 5 | 28th August 2011 01:37 PM |
| Forgot to do this long long time ago | chris ma | Introductions | 2 | 30th October 2003 11:53 PM |
| Long output lead or long output transistors leads? which one to pick? | chris ma | Everything Else | 3 | 6th June 2003 01:06 PM |
| A little help for the beginner? | 959Turbo | Multi-Way | 3 | 10th January 2002 08:52 PM |
| Page generated in 0.11043 seconds (80.09% PHP - 19.91% MySQL) with 10 queries |
