Old 31st December 2012, 10:01 PM   #1
Default NOS Tube: Black Spot on Getter Flashing? Help
Hello,
So i have a very large collection of vacuum tubes and i have been going through them to organize them. There are many instances where there are seemingly NOS tubes that have this small black teardrop shaped mark on the getter flashing. It would seem that this is from "burning" of the tube being used. These tubes test NOS, have their original boxes, have straight pins, all ink is intact, etc... I found this page that has made me think otherwise: TubeSound Blog Archive brown-black getter flashing does not mean ‘Used’!
I have also attached some of my own photos of these tubes. Could you guys clear this up for me.. It is quite annoying. Also, what is the main thing you look for to identify a used tube? Larger octal tubes are usually pretty easy to tell. ANY input on this subject would help me immensely. Thanks very much.
-Madison
Old 31st December 2012, 11:15 PM   #2
maton00 is offline maton00  Mexico
maton00's Avatar
Send a message via MSN to maton00
they sometimes have some black markings in the glass over a near area where the heaters are located and that can tell you some about his life because they apear after some time. look were the heaters conect with the pins (were are solded) if that white stuff (the one that heater filament if covered) its blackened or too thin then you have something to worry about.
Old 1st January 2013, 12:15 AM   #3
TubeHead Johnny's Avatar
If they test new then what are you worried about? Have you tried them in a circuit?
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz
Old 1st January 2013, 01:43 AM   #4
expert in tautology
bear's Avatar
if the markings are browned, then the tube has been run for some time or has gotten too hot, or both. Otoh, if it tests good, it is good.
Tubes are not a beauty contest.
The way the getter is flashed is not a calm slow process... it's more like BANG!
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
VR tube flashing? jarthel Tubes / Valves 3 9th March 2010 05:47 PM
Crinkly tube getter – Is this bad? Pyre Tubes / Valves 6 28th August 2009 02:28 PM
tube is flashing and glowing very bright! pho_boi Tubes / Valves 8 9th February 2006 09:16 PM
Tube flashing safetyman Tubes / Valves 15 7th September 2005 02:26 PM
Flashing Rectifier Tube- Bad Thing? Sherman Tubes / Valves 46 19th August 2005 12:00 AM
Copyright ©1999-2013 diyAudio
