New to valves & this forum. New to valves & this forum. - Page 3 - diyAudio
Old 30th December 2012, 04:29 PM   #21
Arckivio is offline Arckivio  United Kingdom
Panic averted!!! I plugged my line level into the phono & slowly turned it up & it was very loud so I obviously never switched the input selector when I first did it by mistake. From now on I will pay more attention as I'm obviously a whole basket short of a picnic!!!!
Thanks all.
Old 30th December 2012, 04:59 PM   #22
Burnedfingers is offline Burnedfingers  United States
Thanks all.
Son, it isn't supposed to be plugged into the phono section as its a line level device. A whole basket short of a picnic? You may very well be especially if you keep up the practice of using the phono input for other than a phono. If it had been a SS preamplifier you would very well be looking at where you could take it to get it repaired.
Old 30th December 2012, 05:22 PM   #23
I know, I know sir. The first time it was a mistake plugging it into the phono, secondly, I never actually had switched it to phono so I ended up thinking my input was broken. Without a turntable to try it with, this afternoon was just to check if it was defective or if I hadn't originally switched it over, Hence the low volume initially.
New to valves & this forum.Hide this!Advertise here!
Instrument Amp threads in Tubes/Valves Simon B Forum Problems 9 15th April 2012 11:19 PM
Hybird Headphone Amp: Help with Valves! b1o2r3i4s5 Headphone Systems 4 16th February 2012 08:08 PM
8233, 8116 & 6BZ6 valves - what are they good for? jack daniel Tubes / Valves 62 28th February 2008 01:04 PM
First amp for a new in valves JORGETronic Tubes / Valves 2 12th June 2006 01:38 AM
Any subs for 6N1 & 6N2 twin triode valves? rcavictim Tubes / Valves 39 20th April 2005 02:19 PM
Copyright ©1999-2017 diyAudio
