Pairs of resistors in opposite directions - Page 6 - diyAudio
Old 22nd January 2013, 06:53 PM   #51
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by regiregi22 View Post
Hello,
I am just about to start building this amplifier. The circuit calls for using pairs of resistors in opposite polarities (If we could call it polarity being a resistor), from what I've read that may reduce/cancel inductance. I have never done that in any of my previous amplifier designs, and neither seems to be a common practice. Is that really necessary or did the designer done that the same way he could have used silver wire or isolation feet?
Does it really make a difference to make it worth it to implement that way?
PP2012 - KT88 Hi-End Push Pull Amplifier
Best regards
I don't see anything extreme-higend in this amp. -40 dB of 3'rd harmonic plus grass of higher order harmonics, unreliable solder joints; can decreasing inductance that starts acting at tens of megaherts help? I don't think so.
The Devil is not so terrible as his math model is!
Old 22nd January 2013, 09:35 PM   #52
adason is offline adason  United States
adason's Avatar
you guys got that all wrong...its for AC current, if the current goes one way, it goes through one resitor, if it goes the other way, it uses the other resistor
Old 22nd January 2013, 09:40 PM   #53
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
But... but... are we talking about the usual positive-to-negative current, or the physical-world negative-to-positive current for the same ambipolar resistors?
Old 22nd January 2013, 10:12 PM   #54
DF96 is offline DF96  England
Could be positronic current, or electrons going backward in time.
Old 22nd January 2013, 10:32 PM   #55
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
Depends on Coriolis efect, I bet
Trans with two pairs of primaries and two pairs of secondaries = two transformers Apuesto Paul Power Supplies 1 1st April 2012 06:16 PM
2 pairs of 3" fullrange, some tweeters, and 2 pairs of PE Alesis buyout woofers tuxedocivic Swap Meet 0 18th August 2011 10:36 PM
Opposite moduli expoy composite Alain Favret Multi-Way 1 29th August 2006 09:57 PM
400+ 5% carbon comp resistors 1/8-2W 1% or better matched pairs available sdedalus Swap Meet 3 22nd June 2006 05:31 AM
Copyright 1999-2017 diyAudio
