#31 |
I just noticed a Vandal Resistant Push Button Switches on the page, dont use it as power switch, it is only rated to 48VDC
Regards Max |
#32 |
Oh, a pair of resistors ... to do the work of "one" ... has a lot of utility! It is certainly the cheapest way to get higher-wattage dissipation tolerance, if space and layout is of little concern. Series-connected resistors are also quite a bit more tolerant to over-voltages (which for most amplifiers isn't really a concern). Did I mention "cheaper"? Its usually true: a pair of 1/2W resistors is usually less expensive than a 1W. Oh yes ... there's also increase-in-precision: the variance from stamped-on value tends to average by the number of resistors placed in parallel (or series). The increase in precision beats specially-vetted high-precision resistors any day (at least when manufacturing the things). Its also possible to use DIFFERENT resistors - with different temperature coefficients, to cancel each other's drift. Did that all the time up at LBL. Hmm... and cheaper.
Of course, the most-usual reason of all for using a pair or trio of resistors is to obtain a harder-to-find resistance value with off-the-shelf-in-your-lab candidates. That too saves money. And time. And frustration when the wrong part arrives. GoatGuy |
#33 | |
#34 |
Ah, but it can be very important for consistency rather than accuracy of stated value, for instance in push/pull or balanced circuits. That's why the Jensen discrete op amp uses an integrated circuit with massively paralleled transistors...the resulting characteristics are statistically averaged and achieves precision consistency so any two production items are perfectly matched. In theory...
#35 |
Just been doing a bit of maths, combining normal distributions with the paralleling resistor formula.
I make it two 1% sd paralleled resistors of equal value become a 1.6% sd resistor, so paralleling is bad, not good. The error gets smaller, but not by as much as the resistance gets smaller, so comparatively the error is bigger. However, combining series resistors does improve things. Two 1% resistors become a 0.7% resistor. Of course I could have royally messed up here. Last edited by Robert Kesh; 9th January 2013 at 11:55 PM. |
#36 |
Massively parallel transistors are almost always for low noise, not consistency. BJTs are very consistent in following the Ebers-Moll exponential model.
Paralleling resistors should have the same effect on error as putting them in series, as you are just adding the conductances instead of the resistances. |
#37 | |
for adding, multiplying and dividing standard deviations see. http://www.cartage.org.lb/en/themes/...ubtraction.htm Multiplication and Division of Values with Standard Deviation Last edited by Robert Kesh; 10th January 2013 at 10:54 AM. |
#38 |
If you have 10% resistors then it is better to buy better resistors.
If you have 1% resistors then +-1% gives +1.01/-0.99% which is close enough for the Central Limit Theorem to work its magic. |
#39 | |
CLT is for the arithmetic mean of many samples, and so works for their sum too, which is why it works for series resistors, hence the 1/sqrt(2) in my first post on this, sd will reduced by a factor of 1/sqrt(n) for n similar resistors. Paralleling resistors is related to the harmonic mean. I am not convinced it gives a similar result to the CLT. Though I confess I did the numbers when I was very tired. |
#40 |
I see only one reason to connect resistors parallel in opposite direction: the stamped value (or the color code) can be read from either side...
| Trans with two pairs of primaries and two pairs of secondaries = two transformers | Apuesto Paul | Power Supplies | 1 | 1st April 2012 05:16 PM |
| 2 pairs of 3" fullrange, some tweeters, and 2 pairs of PE Alesis buyout woofers | tuxedocivic | Swap Meet | 0 | 18th August 2011 09:36 PM |
| Opposite moduli expoy composite | Alain Favret | Multi-Way | 1 | 29th August 2006 08:57 PM |
| 400+ 5% carbon comp resistors 1/8-2W 1% or better matched pairs available | sdedalus | Swap Meet | 3 | 22nd June 2006 04:31 AM |
