Pairs of resistors in opposite directions - Page 3 - diyAudio
Old 8th January 2013, 06:38 PM   #21
There is a small reduction of coupling inductance and capacitance by winding in sections. Using two in series is like winding in sections.
Old 8th January 2013, 09:45 PM   #22
DF96 is offline DF96  England
Two resistors in series will have exactly the sum of their resistances and approximately the sum of their inductances. This may be smaller or larger than the inductance of one resistor of the total value, but larger is perhaps more likely.
Old 8th January 2013, 09:45 PM   #23
Mikha is offline Mikha  Russian Federation
Noise. Parallel connection of resistors to reduce noise, the value of which depends on the current.
Old 8th January 2013, 11:00 PM   #24
On Hiatus
SY's Avatar
Johnson noise is the same, it just depends on the resistance. Ditto excess noise, it only depends on the applied voltage which is the same for any parallel combination.
And, of course, it's pretty much meaningless at these voltage levels. If one wants to reduce it to zero, a wirewound resistor is the best choice.
Good review: https://dcc.ligo.org/public/0002/T09...rent_noise.pdf
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th January 2013, 11:37 PM   #25
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
In short: carbon comp aside, there is damn little you can argue against modern resistors. That anything obeys Ohm's Rule (it should hardly be called a law, most things don't obey it!) at all is quite remarkable, and that resistors do, so well, so precisely and over so many orders of magnitude in voltage, current and frequency, is probably unmatched in electrical engineering, and perhaps in all other engineering disciplines as well. (Well, okay, perhaps astrophysics has us beat with something like the mass of a planet in orbit -- that could be a pretty pure gravitational tone in the nanohertz, and just imagine how little Johnson noise a 10^24 kg "capacitor" will have, even at that frequency! But then, I specified _engineering_, and I don't see no astronomers pulling planets into new orbits, do you? )
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 9th January 2013, 02:36 AM   #26
In most cases when you see a proud inscription "Hi End," you have to forget about engineering...
Old 9th January 2013, 09:15 AM   #27
Robert Kesh's Avatar
You guys should just do this
Just make sure you have reversed the helix's orientation to the resistor's.
Old 9th January 2013, 09:36 AM   #28
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I can see vendors , selling Beyschlag's - sorted to left and right ones
"... combine them in parallel , as seen on TV! "
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th January 2013, 10:26 AM   #29
At least the EM field conserves parity, so a left-hand wind and a right-hand wind are the same apart from polarity. If we had to do electronics using the weak interaction it would be much more fun, as that violates parity!
Old 9th January 2013, 10:31 AM   #30
Zen Mod's Avatar
if you place them around xtall , then they're really useful
Trans with two pairs of primaries and two pairs of secondaries = two transformers Apuesto Paul Power Supplies 1 1st April 2012 05:16 PM
2 pairs of 3" fullrange, some tweeters, and 2 pairs of PE Alesis buyout woofers tuxedocivic Swap Meet 0 18th August 2011 09:36 PM
Opposite moduli expoy composite Alain Favret Multi-Way 1 29th August 2006 08:57 PM
400+ 5% carbon comp resistors 1/8-2W 1% or better matched pairs available sdedalus Swap Meet 3 22nd June 2006 04:31 AM
Copyright 1999-2017 diyAudio
