Old 25th December 2012, 08:33 PM   #1
Default Simple hybrid amplifier (35W/8Ohm)
*** LATEST SCHEMATICS ARE HERE *********************************
LINK: Simple hybrid amplifier (35W/8Ohm)
I have built tube / power opamp hybrid amplifier.
Tube preamp section is CCDA circuitry from John Broskie, which drives power opamp OPA548T connected as unity-gain voltage follower.
It sounds good, has that smoothness of tube and you can listen to the amplifier for long periods of time without any fatigue.
Old 19th January 2013, 08:43 AM   #2
Default Project update
I have updated few things. Mainly, I have changed preamp to aikido with noval tubes, because of better availability of ECC83 and ECC82 than 6SL7.
There are also some changes in the power supply and power amp.
Thinking about adding EQ, because some people really need one with their speakers/listening conditions.
Old 19th January 2013, 09:09 AM   #3
I am a little puzzled. Wouldnīt it be easier to lessen the feedback of the OPA548 to get 20dB gain instead of zero and skip the tube section?
Old 19th January 2013, 09:22 AM   #4
Ofcourse you can do that. Then you have nice IC chip amplifier. But I want sound of tubes without output power tubes and output transformer.
Old 19th January 2013, 09:37 AM   #5
Canīt see the difference. What you have is a tubepre capacitorcoupled to a 90dB feedbacked chip amp ;-).
Old 19th January 2013, 09:39 AM   #6
There is difference in what will amplify voltage. Either tubes or transistors in chip, I prefer tubes for voltage amplification.
Old 19th January 2013, 09:44 AM   #7
You still have 90dB raw gain in the chip. The amplification inside the chip does not lessen with more feedback. But if you lessen feedback, fidelity usully gets better.
Old 19th January 2013, 09:54 AM   #8
Opamp is configured as buffer, it does not amplify voltage, just current.
Old 19th January 2013, 10:24 AM   #9
...why not a couple of vmos sorce follower?
Old 19th January 2013, 10:30 AM   #10
In class AB without feedback around mosfet source follower you will have much more distortion. You could use class AB BJT follower output stage, but it should have about 4 to 5 pairs minimum of parallel devices to have small distortion and high damping factor.
Simple mosfet source follower works better in class A, which I donīt want because of so much heat.
Help Needed with simple hybrid microphone pre-amplifier Abdulla Solid State 8 23rd September 2012 06:29 PM
Simple, powerful (100W-200W into 8ohm) amplifier schematic needed ddog Solid State 14 23rd April 2004 04:36 AM
looking for 25-35W simple amp schematic Mr. Triatic Solid State 2 15th February 2003 09:06 PM
Copyright Đ1999-2013 diyAudio
