Dynaco ST70 big Snorting noise. Dynaco ST70 big Snorting noise. - Page 2 - diyAudio
Old 24th December 2012, 09:42 AM   #11
Burnedfingers is offline Burnedfingers  United States
Originally Posted by mmmalmberg View Post
Got it. Thank you all! Basic diagnostics I guess, I should have thought of it, if you have one good channel, start comparing and see what's different. Per Chip647, I checked the resistance on each of the inputs. ~150K on the good side and open on the other. That made it easy for me to go over the board with a loupe and I found a sneaky little missed connection. Soldered that up and bingo, silence. Yay! Thanks again.
That is why I mentioned re-soldering the connections.
Old 24th December 2012, 03:57 PM   #12
mmmalmberg is offline mmmalmberg  United States
Yep, makes sense - thanks!
Old 24th December 2012, 05:28 PM   #13
Originally Posted by Tesla88 View Post
If you swapped the Output Trasformer primary connections for mistake , the NFB work like a positive feedback , in most case you get a self oscillating amplifier that produces a squealing sound so is easy to spot because amp wont work at all
That's great information; when I was recently putting new (Audioregenesis) boards in my son's Dynaco SCA35 I was wondering what would happen if I got those wrong. Thankfully I got it right but now I know the alternative Thanks again...
And Happy Holidays to all
Dynaco ST70 big Snorting noise.Hide this!Advertise here!
Dynaco st70....Can I use 6 ohm speakers? OPTI-MOS PAT Tubes / Valves 6 11th October 2010 02:09 PM
Dynaco st70 vs Heathkit W5M Rudes Tubes / Valves 10 10th September 2009 12:45 PM
DIY Dynaco ST70 wingking3000 Tubes / Valves 2 25th July 2008 10:20 PM
Dynaco ST70 clone Tekko Tubes / Valves 8 9th April 2005 02:02 PM
Dynaco ST70 cwteoh Tubes / Valves 14 27th May 2004 06:07 AM
Copyright ©1999-2017 diyAudio
