Good Soft Distortion
Old 23rd December 2012, 03:39 PM   #11
costis_n is offline costis_n  Greece
Now, would I be evil if I said The Invasion Of The Double Digits ?
Old 23rd December 2012, 10:57 PM   #12
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by Tesla88 View Post
Thanks but what about Do It with Tubes?
I assume this is for recording studio use? If so, the parts selection and construction technique are pretty demanding, if you are up to the task, you can check out Gyraf's DIY projects: Gyraf Audio - G9 DIY.
And if your friend just want something "tubey" to fool around with at home, there are many soundcards with tube preamps built-in for decent prices. Not trying to talk you out of the project, but just a reminder that there is a huge difference in requirement for pro vs amateur use...
Jaz
Old 23rd December 2012, 11:42 PM   #13
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
My friend is a studio engineer with an SSL analog mizer, i built some stuff for this studio like a pair of 1176 compressors , a cabinet simulator for guitar , DI boxes , etc
So he's not a fool who likes having nice looking preamp with a tube lighted by some blue leds
Really don't know what he wants this time , he gave me some vocal tracks for test saying try to give some warm and color...
I started from a single stage form 6CG7 with a 47k load on the plate and a trimpot from K to Ground to obtain a well balanced distortion , only tested with sinewave.
I read carefully all of you stated , please go on with suggestions , i really appreciate!
And sorry for my bad english...
Old 24th December 2012, 02:53 AM   #14
jazbo8's Avatar
Since your friend is a real pro, please take a look at the Gyraf's site for more information, even if you don't end up using their design, you can still get some ideas for your build, good luck with your project, keep us posted on how it turns out.
Jaz
Old 24th December 2012, 08:36 AM   #15
Tesla88's Avatar
I looked at the gyraf , intresting stuff
Sure , i hope to do something in these days , but i'm goig to build a pair of 1176 compressor again these days . must be ready for january
Anyway once they're finished i'll try to do something on this project.
Please keep posting intresting ideas/schematic
Have a nice day a merry xmas
Old 24th December 2012, 11:19 AM   #16
DF96 is offline DF96  England
Buy a cheap Chinese tube buffer off ebay. They add lots of 'tube sound', by using low supply rail voltage etc.
Old 24th December 2012, 03:09 PM   #17
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Pick a tube of your choice that is known for good neutral sound capability. Build a clean buffer stage with a cathode follower to give good drive ability. Now add a coupling cap (.22uF 450V) to a 50K pot and an additional 5K resistor to ground from the anode of the first stage. As you decrease the resistive load on the anode, second harmonic distortion will go up.
For instance, I'm testing a 6CB6 (Triode strapped) with a current source load and fully bypassed cathode. At 200V on the anode, and 1.5mA through the tube I get second harmonic less than -80dB (0.078% thd) and third below -90dB. Not fantastic, but a good gain stage.
If I add a 2.2uF cap in series with a 10K resistor to ground, the second harmonic goes to -32dB and third only increases to about -72dB.
Voila! Tube sound. 3.6% second harmonic THD.
The downside is as one increases the anode load to increase second harmonic distortion, one also increased the load on the stage and gain decreases. Thus, you need a gain control between stages to allow you to compensate for the decreased gain as you increase distortion.
Good Soft DistortionHide this!Advertise here!
Hyperx soft start any good for valve amp situation? data Tubes / Valves 0 25th September 2011 07:33 PM
Free to good home..HP 302a distortion analyzer-needs work boywonder Swap Meet 8 12th March 2010 01:58 PM
Redneck speaker setup-good sound, or distortion? keantoken Multi-Way 15 26th August 2006 06:19 AM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
good free/soft ware for Mac? brymway Multi-Way 1 3rd January 2004 12:05 AM
Copyright ©1999-2017 diyAudio
