Circuit or schematic for current source of 7.5mA
Old 26th December 2012, 05:35 AM   #31
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by Gost22 View Post
Please be more specific your offer for circuit or schematic to solve the problem.
thank you!
Which problem: to make an amp that works like non-linear attenuator?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 26th December 2012, 06:10 AM   #32
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
thank you!
As Kevinkr noted.
http://www.diyaudio.com/forums/diyau...no-preamp.html
This is a good thread to start with.
Old 26th December 2012, 06:40 AM   #33
EUVL is offline EUVL  Europe
Not that I feel obliged to solve your problem.
But just for my own documentation.
Patrick
xen-audio.com
Old 26th December 2012, 09:16 AM   #34
Gost22 is offline Gost22  Bolivia
Banned
What's wrong with this solution for the BS170?
Old 9th January 2013, 02:51 PM   #35
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Hi all!
How about something like this for source constant current at the cathode?
Or you can offer something better.
thank you!
I'm not a tube guy, but it seems to me that with a CCS in the cathode, there will be no signal current through the tube and hence no output signal on the plate.
Is that what is wanted??
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 9th January 2013, 04:22 PM   #36
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Default Simple R:2R divider does the trick.
This solves the problem - while maintaining the elegance of a constant-current device, allowing the cathode to take on whatever value (voltage bias) necessary for the tube's nominal operation. A couple of resistors in a voltage-divider orientation and a low bias-point JFET get the job done, for maybe less than a dollar.
Old 9th January 2013, 09:15 PM   #37
Ketje is offline Ketje  Belgium
Ketje's Avatar
How about like this
Mona
Old 9th January 2013, 10:06 PM   #38
GoatGuy's Avatar
Originally Posted by Ketje View Post
How about like this
Mona
That one's perfectly workable as well ... with the exception that it needs the cathode-side NPN bypassed to become a constant-current constant voltage power supply as well (in DC), and a variable current, constant voltage supply in the A/C domain.
GoatGuy
Old 10th January 2013, 02:25 AM   #39
Banned
Hi all!
What is a better solution (see graph)
I go with the anode resistor Ra=10k (+B=170V) and cathodic current of 7.6mA and the anode resistor Ra=8K2 (+B=150V) and cathodic current of 7mA.
What is the better of these two solutions for cathodic current of 7.6mA.
What do I get with this solution is better than GoatGuy or Ketje, or go with the cathode resistor Rk=263R for Ik=7.6mA (Rk=286R for Ik=7mA)?
Thank you for your cooperation.
Cheers!
Old 10th January 2013, 03:29 PM   #40
GoatGuy's Avatar
Hi all!
Cheers!
Hmmm... i think your trying to ask "which is better", without having a sense of "what I am trying to accomplish" with the amplifier stage!
Its REAL simple... if you are trying to INCREASE gain, you use higher resistor values, and higher voltages in the power supply. It has long been forgotten, but the "reason" we use the values that are common-and-popular ... is because in the old days, resistors were expensive, wickedly so ... and therefore within the limits of power dissipation and safe circuit operation (all the capacitors blow if too high voltages are used, and the tube "fades to death", or has its heater fail) ... so its all a compromise.
The DESIGN POINT (typically, though not always) for a non-output amplification stage is this: the plate voltage should be far enough below the supply voltage so that the very widest voltage-swings expected ("designed for") the input, on amplification, result in a clean full-range waveform on the output. Unless you're designing (intentionally) a fuzz box or guitar-amplifier 'coloration stage', then for HiFi audio, lower amplification, more linear operation, closer to the "midpoint" of the V+ supply ... applies.
V+ = 150 and Rplate = 8.2 kohms will not be significantly different (except for gain) over V+ = 170V and Rplate = 10K ... -0.81 db, when you take the effect on mu and operating point into effect.
GoatGuy
Circuit or schematic for current source of 7.5mAHide this!Advertise here!
Source for current Sony DVD Schematic? moray james Digital Source 0 9th October 2010 06:55 AM
Source for 1.5mA Constant Current Diode in UK / EU? thermionic Parts 4 29th October 2009 09:34 PM
EL84 driver tube, with less than 5mA current then_dude Tubes / Valves 21 4th December 2007 07:44 PM
Constant Current Source Circuit mrfeedback Solid State 8 22nd April 2002 05:07 PM
