Old 22nd December 2012, 11:08 PM   #11
DUG is offline DUG  Canada
Gost22:
Three cheers to someone who knows how to put a load line on a plate characteristic graph.
Doug We are all learning...we can all help
Old 23rd December 2012, 04:55 AM   #12
Gost22 is offline Gost22  Bolivia
Gost22's Avatar
Hi kevinkr!
CCS in the plate circuit-define what you mean this?
I let the schematic.
thank you!
Old 23rd December 2012, 05:33 AM   #13
Gost22's Avatar
Hi all!
How about something like this for source constant current at the cathode?
Or you can offer something better.
thank you!
Old 23rd December 2012, 06:50 AM   #14
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Read what Kevinkr wrote.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 23rd December 2012, 07:11 AM   #15
aardvarkash10's Avatar
op, why do you want a ccs in the cathode?
"Folks, you can't prove truthiness with information. You prove truthiness with more truthiness. In a process known as truthinessiness." - Stephen Colbert, The Colbert Report
Old 24th December 2012, 07:55 AM   #16
Gost22's Avatar
Hi all!
Merry Christmas and happy NEW YEAR!
Cheers!
Old 24th December 2012, 02:57 PM   #17
zigzagflux's Avatar
What post #9 says. LED in the cathode is all good.
See the 6SN7 stage in the attached schematic.
Old 24th December 2012, 03:25 PM   #18
EUVL is offline EUVL  Europe
Just to see if I can find a solution to the problem, without trying to justifying it.
Problem to solve : low noise CCS 7.5mA at 2V headroom.
Proposed solution :
5x heavily-degenerated 2SK246BL with matched Idss in parallel,
and 1x 100~125R common source resistor (for all 4 FETs) to generate the negative Vgs as required.
Adjust resistor value to achieve 7.5mA.
Should be lower noise also than a BS170, and without the added complication of an opamp-based circuit.
Patrick
xen-audio.com
Old 24th December 2012, 04:30 PM   #19
Do you have a drawing of or can you describe the CCS you used for the 6SN7? I didn't see it on the drawing.
My new years resolution is to build a 6SN7 stage with a horizontal load line to drive an 845 transmitter triode. I have some DN2540s on order now but am still reading up on the subject and am interested in other schemes.
Old 24th December 2012, 05:00 PM   #20
kevinkr's Avatar
Take a look at SY's "His Master's Voice" article for a good example of the cascode CCS I am thinking of: His Master's Noise: A Thoroughly Modern Tube Phono Preamp
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Source for current Sony DVD Schematic? moray james Digital Source 0 9th October 2010 06:55 AM
Source for 1.5mA Constant Current Diode in UK / EU? thermionic Parts 4 29th October 2009 09:34 PM
EL84 driver tube, with less than 5mA current then_dude Tubes / Valves 21 4th December 2007 07:44 PM
Constant Current Source Circuit mrfeedback Solid State 8 22nd April 2002 05:07 PM
Copyright ©1999-2013 diyAudio
