Sakuma's bleeder tubes and series connected transfomers
Old 24th December 2012, 04:35 PM   #31
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Originally Posted by DF96 View Post
Audio seems to have become like the art world: the value of something seems to depend on who did it, rather than any intrinsic merit of form and design. If I put out a circuit like that everybody would rightly (and very promptly) tell me it was rubbish. Far east guru puts out the circuit and everybody worships; they assume that their own concerns about it are merely a sign of their own ignorance of the deeper things of audio. "He must have had a good reason for doing it that way".
Three or four decades later, Tom Wolfe's _The Painted Word_ is more relevant than ever. But now, it applies to everything.
Thanks,
Chris
Old 17th September 2013, 09:20 AM   #32
tassis is offline tassis
The "Teacher" Sakuma, said that: -for an unknown reason to me, adding irons betwenn the stages help the tubes sound better-. He uses series connected transformers to match the signal as he also uses series trans to achieve double voltage for the power supply.
This trick it really works and it sounds maybe better than single transformers do!
Becides we also do this to the electrical enviroments...
Of course there should be lots of theory arguments to this, but the fact is the transformer's action
and behaviewr differs at the working position, so please no comment to the subject.
Regards, Angelos
Old 17th September 2013, 12:58 PM   #33
DF96 is offline DF96  England
I have nothing to add to my previous comments. This thread contains wisdom, but it doesn't come from the fanboys; they are still puzzled.
Old 17th September 2013, 07:10 PM   #34
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally Posted by Vinylsavor View Post
Hi!
I just browsed Sakumas website and found some of his latest works. Sakuma is known for his unconventional circuits. He added some new twists to his latest builds.
There are 'bleeder tubes' added to provide some load to the power supply. Probably for stabilisation. But why use tubes instead of a plain resistor? He even uses expensive DHTs for this purpose like a WE300B here:
12AT7 / 841 SE phono preamplifier
There is even a transformer added as a load to the tube, with the secondary just grounded on both ends.
Here he uses a 50:
5691 / WE-102D SE phono preamplifier
This time even with an input transformer.
There is probably some reasoning behind it, did anybody read the MJ magazines in which these circuits got published? Was there an explanation why this was done?
Also quite interesting the use of several transformers connected in series as a load to enable transformer coupling of high rp tube like the 841:
841 SE Tone control and buffer amplifier
Best regards
Thomas
Active hum bucking circuits. As to why Sakuma would use the audiophool expensive types for this makes no sense, especially when vertical deflection triodes, or pseudotriodes from the 6AQ5, 6V6, or other 6V6-oids, would work just as well for this purpose. Since he's iso-ing both inputs and outputs with ISTs, he could have gone solid statey here and used a MOSFET.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 17th September 2013, 10:22 PM   #35
kevinkr's Avatar
You've missed the point, he's cooking and seasoning to taste, hence his choice of ingredients.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 18th September 2013, 06:49 AM   #36
jazbo8 is offline jazbo8
jazbo8's Avatar
Running the restaurant is his main business after all
Old 18th September 2013, 10:08 AM   #37
jazbo8's Avatar
Sakuma Mini Audio Concert
Old 18th September 2013, 01:58 PM   #38
Magz is offline Magz  United States
Originally Posted by jazbo8 View Post
Five people in a room all trying very hard not to look at each other.
Old 18th September 2013, 02:12 PM   #39
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The Japanese are very passionate and artistic people. So much so they experience passion mainly esoterically with a sense of embarrassment when in public. Its a very different culture.
Old 18th September 2013, 03:48 PM   #40
Defiant is offline Defiant  United States
Defiant's Avatar
I'm with DF96 on this. The thinking that these circuits represent the discovery of some deep, unknown audio phenomena is total crap. This is the same kind of thing that sucks audiophools into spending $2000 on speaker cables, Shakti stones, and Bybee conditioners.
Sakuma's bleeder tubes and series connected transfomersHide this!Advertise here!
CL ad for tubes in MA. FYI only. Not connected dbster Tubes / Valves 0 16th April 2011 07:07 PM
amplifier works connected to PC .. but not when connected to car radio anwaypasible Analog Line Level 1 2nd March 2011 07:42 PM
Glow tubes as series regs ? mach1 Tubes / Valves 4 28th April 2009 09:19 AM
Shuguang Treasure Series Tubes igrant Vendor's Bazaar 3 1st February 2009 05:53 AM
dual secondary transformer connected in series Leolabs Solid State 2 6th October 2006 11:38 PM
