Old 21st December 2012, 10:23 PM   #1
oldschooltube's Avatar
Default Easy Little 6L6 SE
A while ago I was just poking around on the net and ran across this schematic for a 6L6 SE amp at Single Ended Tube Amp project [/URL]
I got bored and started building it one afternoon and just finished it a few days ago and I have to say that for such a simple little circuit it sure sounds great! I just wanted to post about this to share this with those of us who know their way around a schematic and understand how tube circuits work but are by no means "Tube Gurus". It was a fun weekend of soldering point to point and tweaking things around.
Anyway, I recommend this for anyone who wants to give point to point SE a try.
May all of you have a very happy and safe holiday season!
Marty: "Why don't you just make 10 louder?"
Nigel: "...These go to 11."
Last edited by oldschooltube; 21st December 2012 at 10:26 PM. Reason: Add Schematic Photo
Old 21st December 2012, 10:36 PM   #2
HollowState's Avatar
The laminations of your output transformers look like they are arranged for push-pull (no gap), unless there is something about them that I don't know or can't see. Comments?
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 21st December 2012, 11:24 PM   #3
Actually the output transformers are underneath the top plate. Those transformers on the top are the HV on the sides and the filament in the middle. Each channel has its own independent B+ supply.
Old 21st December 2012, 11:30 PM   #4
Ah....that explains it.
Old 22nd December 2012, 05:46 AM   #5
TubeHead Johnny's Avatar
The 200 ohm cathode resistor seems a little low to me for a 6L6.
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz
Old 22nd December 2012, 06:58 AM   #6
But You can use no more 300 ohms.
Old 2nd January 2013, 12:23 AM   #7
Hi, i would like to use a 7591 tube for this circuit. Would you know what kind of changes in component values would be necessary? The B+ will be 320v. thanx in advance, Dak
Old 2nd January 2013, 01:11 AM   #8
The 7591 is a different "kettle of fish". Its drive requirements are much lower that those of the 6L6. Small signal circuitry usually associated with EL84s and 6V6s is appropriate for driving 7591s.
Eli D.
where to buy the 6l6 se amp? DonJuan Elekit 3 2nd February 2012 09:57 PM
2nos of 6l6 in Parallel SE mode kunshri Tubes / Valves 2 15th March 2011 05:15 PM
6l6 Se. longji98 Tubes / Valves 4 17th September 2008 04:33 PM
SE 6l6 HoracioSuarez Tubes / Valves 1 21st December 2007 06:32 PM
5687 to 6L6 SE ? rhcclark Tubes / Valves 4 5th May 2007 02:15 PM
Copyright ©1999-2013 diyAudio
