12au7 valve preamp (again?)
Old 22nd December 2012, 07:53 PM   #11
Gost22 is offline Gost22  Bolivia
Banned
Hi!
After some changes in the schematic, go to the power supply of +B=250V - you see this kind of soundgives this preamp with ECC82/ECC83!
Cheers!
Old 5th January 2013, 06:54 PM   #12
ctcorp is offline ctcorp  Brazil
good evening boys, need to reduce the gain of this thing, what should I change?
12au7 valve preamp (again?)Hide this!Advertise here!
12ax7 12au7 preamp Bengali Tubes / Valves 17 8th January 2012 07:46 PM
Preamp tube SRPP 12AU7 VS preamp tube Aikido 12AU7 = all use rec 6X5GT spiritm2r Tubes / Valves 1 6th March 2011 02:53 PM
3 - 12AU7 Preamp. Is there such an animal? cbj591 Tubes / Valves 12 25th October 2010 10:03 PM
12au7 preamp will not work prorms Tubes / Valves 8 11th November 2007 03:57 AM
Look for 12AU7 Preamp Circuit . RCA245 Tubes / Valves 2 2nd June 2006 02:02 PM
