HT delay pcb...
HT delay pcb...
Old 19th December 2012, 10:37 PM   #11
Alkis is offline Alkis  Greece
Alkis's Avatar
Then use an output relay with a small disc-shaped capacitor connected between the contacts, in conjunction with a delay relay. I presume you don't have an output transformer.
And give your girlfriend the proper directions
plf / amplifier
Old 20th December 2012, 12:30 PM   #12
HVfanatic is offline HVfanatic  Germany
HT delay pcb...
... but the cap will delay turnoff! How do you solve this?
Dirk
Old 20th December 2012, 01:06 PM   #13
Alkis's Avatar
Old 21st December 2012, 10:01 PM   #14
HT delay pcb...
Cap delays switchon, but also switchoff - correct?
Old 22nd December 2012, 02:55 AM   #15
TheGimp is offline TheGimp  United States
TheGimp's Avatar
A diode across the resistor will discharge the cap rapidly at power off. Simple CPU POR trick.
Old 22nd December 2012, 01:32 PM   #16
HT delay pcb...
I think, I have a fundamentalmisunderstanding: A (quite huge) cap takes time to build up the voltage. So relay is delayed. But how can i use the diode? Forward bias would prevent the cap getting charged, reverse bias will do nothing. Can you post a schematic to clarify?
Dirk
Old 22nd December 2012, 03:25 PM   #17
TheGimp's Avatar
Reverse bias will do nothing during the charge phase (power on). However, at power off the diode will become forward biased and rapidly discharge the cap.
Old 22nd December 2012, 04:42 PM   #18
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Zeitsteuerungs-Bausätze - im Conrad Online Shop günstig kaufen
Old 22nd December 2012, 10:20 PM   #19
HT delay pcb...
Hi TheGimp,
please post a schematic, I think, I have a misunderstanding:
Reverse bias will do nothing during the charge phase (power on). OK
at power off the diode will become forward biased NO!!! Voltage stays reverse based, but will decrease...
Where is my misunderstanding???
Old 22nd December 2012, 10:38 PM   #20
TheGimp's Avatar
Like this:
HT delay pcb...Hide this!Advertise here!
High current Jung power supply with HT regulator pcb chris found Power Supplies 0 13th April 2011 07:25 PM
For Sale: Goldpoint SA4 HT passive preamp with HT bypass Face Swap Meet 0 22nd January 2010 02:00 PM
HT without a HT receiver paulspencer Digital Source 28 12th December 2003 08:29 PM
