RIAA triode or pentode
Old 18th December 2012, 10:16 PM   #41
MarcelvdG is offline MarcelvdG  Netherlands
Originally Posted by Merlinb View Post
Bare in mind that your comparative measurements were made with a large resistance in the grid circuit, so grid-current noise could have been a significant contributor to error. This is not a significant source of noise in phono stages, however, since the source impedance is small.
That's why I didn't bother to do any more measurements on the Amperex valve that had 1 uA of grid current. All others had no noticeable grid current. Theoretically that can still mean that two currents cancel each other, like an ion and an electron current, but it is rather unlikely that that happens at all anode bias currents.
Note that 2q*1 uA is already some 4 dB below 4kT/20 kohm, so grid shot noise would not even have dominated on the crappiest Amperex, although it would have caused an error of about 1.5 dB. I don't know/remember if there is such a thing as grid 1/f noise though, do you?
Old 19th December 2012, 05:00 AM   #42
Besides, for both Amperex devices at low currents (few hundred uA), I couldn't hear or see any difference in noise between resistor shorted and resistor not shorted. That is, their very large low-frequency noise at low currents must have been equivalent input voltage noise rather than equivalent input current noise.
For the second Trigon I also measured the A-weighted noise of a complete RIAA amplifier with shorted input using a true RMS meter. Divided by the gain and the root of the noise bandwidth, the result was 10.26 nV/sqrt(Hz) at 1.9 mA bias current, so very much in line with the measurements on the valve itself.
Old 19th December 2012, 06:30 AM   #43
revintage is offline revintage
Hey SY,
I am puzzled!
Did you really get those results on the bench? When loading a Gm with 10k like in your example, simmed results are on par with the same pentode-circuit wrt bandwith and distortion. The Gm has 3dB higher gain though.
It is when unloaded the Gm works(extremely high gain), so you must add a buffer and use a CCS load for the D3a as FrankB indicates.
Also can you explain the original Gm circuit that JC shows that have an ECC82 as Gm-element with its anode fed from B+?
Old 19th December 2012, 08:48 AM   #44
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Oh, I thought you used 47k||1M. Not that the error is huge of course.
No, haven't heard of one.
Old 19th December 2012, 09:35 AM   #45
On Hiatus
SY's Avatar
If by "those results," you mean results similar to Frank's when he had the plate connected and high current running through it, yes. The gain was lower than my earlier prediction which I didn't fully understand, but thanks to the corrections of a few of the posters here, it's because I overestimated the impedance of the emitter.
I'm not familiar with the JC circuit you mentioned.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 20th December 2012, 04:41 AM   #46
You are right, I started with 47 kohm//1 Mohm and later switched to 20 kohm, so only the second Trigon valve was measured with 20 kohm.
RIAA triode or pentodeHide this!Advertise here!
Pentode to Triode Switch Sherman Tubes / Valves 40 6th February 2013 12:06 AM
Pentode to Triode Operation Monjul Tubes / Valves 13 21st September 2010 11:27 PM
Triode versus Pentode Ricky Tubes / Valves 98 20th March 2008 08:43 AM
Pentode to Triode trick. Diy martin Tubes / Valves 4 7th November 2005 11:00 AM
triode=>pentode Lico Tubes / Valves 3 7th April 2004 07:08 PM
