Most exotic SET power amplifier
Old 13th December 2012, 10:15 PM   #1
petavgeris is offline petavgeris  Greece
Default Most exotic SET power amplifier
Hi guys!
As I promised you a few days ago, I will post some pictures of the project I'm now finishing. It is an exotic power amplifier equipped with 211 power tube.
Due to the unique specs, I would say that I'm quite certain that this might well be one of the most exotic amplifiers ever made. There will be several posts regarding the specifications afterwards, for the time being I have uploaded some pictures of this unique project.
It is a 35 W/ch Class A2 power amplifier around 211 output tube, with 300B driver tube and EML20A input tube. There are totally 15 iron pieces spread allover, all of them in double c core configuration. Signal path is 8 cm from input socket to 1st tube grid and around 20cm of copper leads coming out of the OPT secondary, directly soldered onto the loudspeaker connectors.
For the time being enjoy the pictures.
Old 13th December 2012, 10:18 PM   #2
DF96 is offline DF96  England
I suppose it shows that there is no accounting for taste!
Do you need a fork-lift to move it?
Old 13th December 2012, 10:25 PM   #3
Tomorrow I will take some shots with the transformer covers mounted.
Each chassis is very heavy, more than 100 kilos.
Dimensions 120 x 52 cm.
Yes, you might need a forklift!
Old 13th December 2012, 10:40 PM   #4
HollowState is offline HollowState  United States
HollowState's Avatar
Totally uncalled for.
Please tell us what the chassis is made from. I like the smooth finish with rounded corners and the fact that I can't see any bolt heads for the tube socket mounting. But I must say that I don't see the need for so much iron on a monoblock.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 13th December 2012, 10:55 PM   #5
kmaier is offline kmaier  United States
kmaier's Avatar
Wow, it's certainly large and littered with iron. Looks a bit like a small power sub-station. Also interested in the chassis construction. Do you have a full set of specs, i.e., freq. response, power bandwidth, THD, signal-to-noise ratio, etc.? And what are you driving with these large amps?
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 13th December 2012, 11:01 PM   #6
Joe Roberts is offline Joe Roberts  United States
Joe Roberts's Avatar
Excellent work, Sir! A totally insane realization!! Love to see such creations.
I am not sure what "exotic" means but I think that weight and number of transformers factors into the equation somewhere. Also, I like the mercury bridge at the far end.
Look forward to reading more.
How does it sound?
Old 13th December 2012, 11:02 PM   #7
Hello! Thanks for your feedback!
The chassis is made out of highly glossy corian. It is CNC machined with utmost precision at the best technician in Athens. Personally I hate bolt heads jumping out of the surface, so everything was done from the downside. There exist more than 500 bolts on each mono chassis but only two are visible, the ones that connect the IEC mains socket.
The amount of iron is the least required for this design. I have wound everything by myself so I know what I'm writing of. The extraordinary performance of this amp relies on the quality and quantity of iron pieces. There are 7 power transformers, 3 signal transformers (2x IST & 1x OPT) and 5 HV supply chokes, all in double c core configuration. All this per chassis!
Tomorrow I willupload the rest pics, with the covers fully mounted.
Regards from Greece!
Old 13th December 2012, 11:16 PM   #8
How does it sound?
Thanks for your feedback Sir!
This is the 1st of some amps that are going to come. As we progress, level of insanity rizes! Be patient and you will see, trust me!
Yes, the quality and quantity of transformers factors in the equation. Everything is pushed to the extreme. Total weight must be somewhere between 100 and 120 kilos, have yet to check it fully mounted.
The MV rectifiers do not make a bridge, they are 2 simple HV supplies there, one for input & driver stage and another for the output stage.
Freq response is not that extraordinary at first glance (around 30kHz) due to the relatively high impedance of the output tube but the linearity of tubes operation goes well down to subsonics. This is the key of the extraordinary performance of this amp. The signal transformers are monstrous with an enormous amount of primary turns and the freq response is practically the same as the freq response of the output stage. Power output is 35W/ch at <2% Class A2 IST driven.
This amp is going to drive Jadis Eurythmie, the OPT can be reqired for 16 Ohms operation as well.
Thanks for your kind words.
Greetings from Greece!
Old 13th December 2012, 11:17 PM   #9
tomchr is offline tomchr  Canada
tomchr's Avatar
I kinda like the Frankenstein presentation, though, it does raise several safety concerns... Good to hear that you're planning to cover the transformers. I'm curious to see the final product.
The iron does indeed look custom wound. Bravely done.
~Tom
Sizzling Summer Sale going now through August 31st, 2017: Modulus-86, Modulus-286, HP-1, DG300B, and more are all on sale.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 13th December 2012, 11:17 PM   #10
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Thanks for sharing! I wouldn't say that it is the most exotic though, compared to my 833A amp with computer monitoring system and power supply regulated by 300B's
Most exotic SET power amplifierHide this!Advertise here!
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 09:38 PM
An Exotic ClassA Amplifier (never seen before). ontoaba Solid State 8 10th February 2011 08:59 AM
FS: DX Blame MKII amplifier set + power supply + heatsinks supernet Swap Meet 5 29th November 2010 10:33 PM
exotic product ... exotic price Pocoyo Swap Meet 73 20th June 2010 01:44 AM
Iron set for Paraglow (2A3) SET amplifier Alain Favret Swap Meet 1 19th March 2004 06:23 AM
Copyright ©1999-2017 diyAudio
