Help with rogers cadet 3 integrated
Old 13th December 2012, 09:43 PM   #1
mbam55 is offline mbam55
Default Help with rogers cadet 3 integrated
Hi
I'm new to valve amps
I've got a rogers cadet 3 that's not working.
I think I've found the problem but can't read the values of the components due to the damage
I've added a picture of them if anyone can help
Old 13th December 2012, 10:14 PM   #2
DF96 is offline DF96  England
Find a circuit online if possible. Failing that, maybe someone has an intact amp and can tell you the values.
Old 13th December 2012, 11:21 PM   #3
jt1 is offline jt1  United States
Look here:
Google Image Result for http://www.bassboy.com.au/getreel/classicamps/files/amps/rogers/cadet3/images/07.gif
You need to find out why the parts went bad...not just replace them.
Old 14th December 2012, 03:02 AM   #4
rotaspec is offline rotaspec  New Zealand
Those parts are likely not the original problem, they indicate another fault.
Help with rogers cadet 3 integratedHide this!Advertise here!
Rogers Cadet 3 Problem zedrider Tubes / Valves 26 7th January 2018 09:55 AM
Rogers Cadet III Integrated Amp Capacitor Values help timmo1928 Tubes / Valves 4 17th May 2012 09:43 AM
Rogers Cadet III integrated harlequin Tubes / Valves 3 26th March 2010 07:33 PM
Rogers cadet 3 soulie12000 Tubes / Valves 8 29th January 2010 08:13 AM
Rogers Cadet III Schematics needlesview Tubes / Valves 23 14th September 2007 08:50 AM
