Opamps for servos in tube amps - Christmas gift from LT, 12-12-12! - Page 2 - diyAudio
Old 13th December 2012, 10:22 PM   #11
DF96 is offline DF96  England
My thought was that if someone had CDs with continuous compressed pop with dynamic range of about 1dB then the bias circuit would not be able to do anything until the CD finished (74 mins max?). Real music of course has much more variation so plenty of opportunity to adjust bias.
Old 13th December 2012, 11:06 PM   #12
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I don't think for such music precise bias matters. Class B will be fine, no sounds decay.
The Devil is not so terrible as his math model is!
Old 14th December 2012, 11:22 AM   #13
For some music Class C might be sufficient!
Old 14th December 2012, 11:36 AM   #14
palmas is offline palmas  Portugal
I know I'll be using it to have enough voltage from my function generator to drive tubes for testing...
Old 14th December 2012, 11:43 AM   #15
I got that same email !!!
I think of lots of great stuff for that opamp since National Semiconductors version has been no longer available for many many years !!!!
Cheers !!
jer
Old 9th July 2014, 04:37 AM   #16
I got a New Email Today!!!
I see LT is now making a dual version of the LTC6090 it is called the LTC6091!!!!
http://cds.linear.com/docs/en/datasheet/6091f.pdf
http://www.linear.com/solutions/4695...ign=LT_Insider
jer
Old 9th July 2014, 04:42 AM   #17
Typically bias servos for Class AB clamp the current monitor signal at 2 x the idle current before averaging.
Menno/Guido do this a bit differently. They use more gain and a much narrower clamp window about the desired operating point.
Like this:
and Rob did his own variation here:
http://rmsacoustics.nl/rmsacoustics/...-circuits.html
Ian
FAST build with an Alpair 7.3 and a 12" Peavy Pro 12 woofer golgiapparatus Full Range 6 2nd November 2012 12:07 PM
Ultra quiet DC supply +12/-12/+12? phrarod Digital Source 13 10th January 2011 01:33 PM
FS - 12" E-V LT-12 full-rangers dimitri Swap Meet 4 13th May 2009 09:11 PM
12 volt power supply for tube amps caraudionut Tubes / Valves 9 27th April 2007 03:04 PM
CDM-1 servos (Marantz CD-12 aka Philips LLH1000) tvdw Digital Source 9 14th April 2006 02:43 PM
Copyright 1999-2017 diyAudio
