tube amp hum........normal or suggested fix?
Old 4th January 2013, 02:23 AM   #31
wiredwithtubes is offline wiredwithtubes  United States
2. Disconnected ground from RCA jack inputs that ran to ground on large electrolytic caps and connected them directly to center chassis bolt "star ground" to which earth ground and power transformer center tap (red/yellow striped wire) are attached
These changes did two things:
1. The hum in the right channel is gone (this is wonderful)
2. The left channel now has a buzzing sound (this stinks and is worse than the original hum problem).
Is that all you changed, move the ground wires from the input jacks? If so check the ground wire between the left jack and ground. You might want to check those input jacks, they look like they might be insulated from the chassis, one might be touching the chassis creating a ground loop.
tube amp hum........normal or suggested fix?Hide this!Advertise here!
F5 - is normal ICs twist out the Hum? Blink_PT Pass Labs 64 6th December 2012 11:41 AM
Unable to fix hum on my F5 anilva Pass Labs 43 24th May 2011 07:06 PM
Tube Amp Hum Bengali Tubes / Valves 3 12th October 2006 03:47 AM
transformer hum....is it normal??? eddog Chip Amps 4 4th May 2006 07:36 PM
Tivoli Model1 PSU hum fix / upgrade? jives11 Solid State 1 24th May 2004 08:30 AM
