Building a beast: Stereo EL84 auto bias PP tube amp - diyAudio
Old 12th December 2012, 09:48 PM   #1
dLab is offline dLab  Sweden
Default Building a beast: Stereo EL84 auto bias PP tube amp
Just started to build this stereo tube amplifier based on 4 x EL84 and 2 x 6N2P tubes from Die Röhre, Wulfert audio.
Wondering perticulary how to combine volume potentiometer with balanced and unbalanced input (any sugestions). And if power transformer is not shield, it should not affect the quality of sound? If anyone has experience building this kit, all tips will be much appreciated...
Old 12th December 2012, 10:11 PM   #2
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
You can add a toggle switch that can accept either unbalanced or balanced input. The volume pot would be a 4-gang.
I've always had problems having the power transformer so close. It would hum faintly.
Old 19th July 2014, 12:38 PM   #3
The amp is almost built to 100%. Some small things need to be adjusted. I used your idea with the toggle switch. I got terrible switching noise. Any suggestions to eliminate this?
Old 19th July 2014, 07:38 PM   #4
DF96 is offline DF96  England
Signal switches must have identical DC levels on both sides. This may require extra coupling caps and resistors, or get used to never switching when the amp is turned on.
EL84 fixed bias PP Triode DrewP Tubes / Valves 23 24th November 2013 08:17 PM
PP pentode tube headphone amp PCB needed ( 6au6 thru el84) speakerfritz Tubes / Valves 5 28th November 2010 01:24 AM
Suppo Audio EL84 PP Tube Amp boudy Swap Meet 2 15th February 2010 01:42 PM
Magnavox 175 Stereo Tube Amp (PP 6V6) GordonW Swap Meet 2 13th September 2007 12:21 AM
EL84 SE auto bias alexmoose Tubes / Valves 10 8th April 2007 02:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
