Double feedback pentode Power Stage
Old 12th December 2012, 10:30 AM   #1
costis_n is offline costis_n  Greece
Default Double feedback pentode Power Stage
I came up with this concept for a power stage, using pentodes.
The idea is to get maximum power from two pentodes, and keep the feedback only in the output stage, while keeping distortion down. As I read here, partial feedback output stages are best driven by high output impedance driver stages.
-Anode to grid feedback
-Balanced feedback from the output trannsformer
-Fixed biasing
G2 power is omitted for clarity. Possible options for feeding G2 are a properly stabilised power supply, or a plain simple resistor a-la RH84. Pleas comment on that too.
Opinions?
Old 12th December 2012, 11:12 AM   #2
LinuksGuru is offline LinuksGuru  Europe
Penthode + CFB (using secondary) is nothing new. Take a look at Sansui AU70 schematic. That will work for sure.
Anode to grid feedback - what is it for ???
Additionally, if you want to implement CFB (cathode feedback), its better to use separate tertiary winding instead of secondary.
Old 12th December 2012, 11:39 AM   #3
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
One of the advantages of NFB is to low the output impedance when properly used.
Cathode feedback is voltage-series feedback, and then it effectively reduces output impedance.
Anode to grid FB is current parallel, which increases output impedance, so since this point of view, they cancels out together or almost counteract.
The advantage in respect to lower the distortion continues to work of normal way.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 12th December 2012, 12:30 PM   #4
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Local feedback 50 years ago
Old 12th December 2012, 12:33 PM   #5
On Hiatus
SY's Avatar
Anode to grid FB is current parallel, which increases output impedance...
Are you sure about this?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th December 2012, 12:38 PM   #6
I am pretty certain that anode to grid reduces output impedance too...
By the way I never said I invented this, just exploring the possibility of combining these two kinds of feedback plus fixed bias.
Old 12th December 2012, 01:30 PM   #7
ruben alstad is offline ruben alstad  Norway
Cant you use a normal output transformer with an additional cathode winding for the feedback?
Old 12th December 2012, 01:57 PM   #8
Are you sure you are alive or you are dreaming?
Old 12th December 2012, 02:35 PM   #9
Palustris is offline Palustris  United States
Palustris's Avatar
Audio Research did this cathode feedback scheme with the ST 70.
ARC ST70C3
The Tango XE-45-5 PP output transformer has a secondary tap for cathode feedback.
Feral Eye
Old 12th December 2012, 06:54 PM   #10
lcsaszar is offline lcsaszar  Hungary
And the Quad II did it
Double feedback pentode Power StageHide this!Advertise here!
Powerdrive for PP amp with local feedback and pentode driver ? Jaap Tubes / Valves 5 5th November 2009 09:58 AM
Single Ended Pentode Spud and Feedback dsavitsk Tubes / Valves 32 10th October 2009 06:26 PM
Help on Pentode Octal Phono Stage (POPS) smbrown Tubes / Valves 9 31st January 2008 01:44 AM
An idea for a partial feedback pentode amp using 6AU6's and 807's Shoog Tubes / Valves 60 19th August 2007 10:26 AM
Pentode vrs Mosfet “MU-Stage” sgerus Tubes / Valves 1 19th June 2006 08:21 PM
