Double feedback pentode Power Stage - Page 2 - diyAudio
Old 12th December 2012, 10:03 PM   #11
Also Sansui AU70, A111, some Fishers, and of course McIntosh.
Old 13th December 2012, 04:49 PM   #12
you guys seem to know every amplifier with tertiary feedback ever made. Congratulations!
Old 13th December 2012, 05:29 PM   #13
kevinkr's Avatar
Originally Posted by Osvaldo de Banfield View Post
Are you sure you are alive or you are dreaming?
It's a PP variant of the RH topology, there is local negative voltage feedback from output tube plate to grid based on the ratio of the rp of the preceding stage and the plate to grid feedback resistor. It does lower rp in the output tube significantly depending on how much feedback is employed.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th December 2012, 06:05 PM   #14
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Not always what you say is true. There are 4 elementary kinds of feedback:
1) Voltage series: this is a when beta (The feedback ratio) senses voltage at output and feeds back voltage. This way input impedance is boosted, and output impedance is lowered (The most common form is a noninverting op amp with 2 feedback resistors);
2) Voltage parallel: beta senses voltage, and feedback current, input and output resistance are lowered;
3) Current series, both the output and input impedances are boosted (Triode with Rk without caps, also used in chips for vertical deflection in CRT displays);
4) Current parallel, which current in the output is sensed, and feedback as a current in the input, output impedance is boosted, and input is lowered (It makes a better current controlled current generator).
As a difference with other thread which I demonstrated my words, I will not do it here because in any textbook can be found such as demonstrations.
In some circumstances, topology of feedback can be mixed and it includes positive feedback, in the Seely´s book it is said that sometimes an amplifier can have a mix of positive current feedback and negative voltage feedback in order to obtain zero or negative output impedance.
Sorry if my English is not too good, but I believe you can understand me.
Cordially Osvaldo.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 14th December 2012, 06:55 PM   #15
Any opinion on the topic?
Old 14th December 2012, 07:27 PM   #16
Nah!
Old 15th December 2012, 01:11 AM   #17
can Ultra-Linear and a cathode feedback output transformer winding be implemented in one output stage?
Old 15th December 2012, 04:37 AM   #18
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
If you leave the screens connected as normal pentodes, arguably CFB already does this. If you want to do it "more", there's nothing wrong with that.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 15th December 2012, 01:46 PM   #19
And why lose power using ultralinear, you can use an off the shelf transformer with pentode connection and no extra windings!
Old 15th December 2012, 02:37 PM   #20
Yes, you will get benefits of both, actually I did it in 2 push-pull amps.
For details you can look for a book written by Menno van der Veen (I recommend last edition).
Powerdrive for PP amp with local feedback and pentode driver ? Jaap Tubes / Valves 5 5th November 2009 10:58 AM
Single Ended Pentode Spud and Feedback dsavitsk Tubes / Valves 32 10th October 2009 07:26 PM
Help on Pentode Octal Phono Stage (POPS) smbrown Tubes / Valves 9 31st January 2008 02:44 AM
An idea for a partial feedback pentode amp using 6AU6's and 807's Shoog Tubes / Valves 60 19th August 2007 11:26 AM
Pentode vrs Mosfet “MU-Stage” sgerus Tubes / Valves 1 19th June 2006 09:21 PM
Copyright ©1999-2017 diyAudio
