EL34 PushPull UL Amp
Old 12th December 2012, 04:55 AM   #11
artosalo is offline artosalo  Finland
artosalo's Avatar
Originally Posted by Eli Duttman View Post
Has anybody paid attention to the fact that the O/P trafos lack the magnetic headroom needed to cope with a GNFB induced low freq. error correction signal?....
Would you clarify this, please ?
Old 12th December 2012, 10:28 AM   #12
roline is offline roline  United States
roline's Avatar
The output iron was not the issue. If you use a cathodyne driver or LTP driver with stones and a .2u or .3u coupling cap, massive amounts of feedback are not necessary. Be sure to have a solid power supply. I like a diode bridge to large cap -L- large cap to a slow start pass tube diode to large cap. That is the B+ in the KEG-EAR amp.
4.3k iron prefers to be driven by 6550 and KT88 tubes. I tried 6P3S, 5881, 6P3S-E, EL34, 6L6GC and they were wonderful with 6.6k but fell short driving the 4.3k iron at volume. They required lots of feedback to do so. So there was another weakness. Also 6.6k Ra iron will give you more class A output with overall lower power out. 4.3k gives you more power out but less class A operation.
One advantage of the LTP is the use of local feedback plate to gate (220k) on the output tubes some call Schade feedback. I tried to drive 4 ohm speakers on 8ohm taps that would change the 6.6kRa iron to look like 3.3kRa iron. the little 6GV5 sweep tubes did not even notice the difference.
Strong recommendation would be to use a LTP to drive the output tubes with 220k plate to gate localized feedback to drive the 4.3k iron.....
You might want a little GNFB if that at all.
SO many tubes, SO little time!!!
Old 13th December 2012, 07:25 AM   #13
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
Hi guys , thanks for the replies
People often say that. Often because they have heard someone else say it.
I think a 12AX7 in a cathodyne configuration would be ok to drive a pair of EL84 or tubes quite easy to drive , to drive a pair of EL34 i think you need more driving capacity , es 12AU7 , 6CG7 , 6SN7 ...
I've a question about Dynaco ST70 , the 7199 tubes are rare and expensive , is there any kind of tube I can use instead? Es. one pentode for input like EF86 and one triode (6cg7?) for the drive section?
What do you think about this kind of circuit :
http://www.triodeel.com/achpwill.gif
On evening i will start bench testing the Acrosound schematic ,but i would like to test the Dynaco also, so any replies would be great!
Best regards
Old 13th December 2012, 01:48 PM   #14
DF96 is offline DF96  England
12AX7 is rarely seen as a cathodyne PS; more often as LTP. EL34 are fairly easy to drive. Remember, if you are using global NFB (as most of the classic EL34 designs do) then you need some HF rolloff to stabilise the loop. If your circuit does not naturally include this then you have to add it somewhere.
I think some people have had success by replacing 7199 with ECF80/6BL8? Might need rewiring and a few component changes.
Old 13th December 2012, 02:08 PM   #15
rongon is offline rongon  United States
rongon's Avatar
I remember Van Alstine using 6GH8A as a sub for 7199, after rewiring the tube socket connections. Isn't 6U8A also a close equivalent to 6GH8A?
Old 13th December 2012, 02:10 PM   #16
artosalo's Avatar
Originally Posted by Tesla88 View Post
...I've a question about Dynaco ST70 , the 7199 tubes are rare and expensive , is there any kind of tube I can use instead? Es. one pentode for input like EF86 and one triode (6cg7?) for the drive section?...
I can suggest one especially well working tube/cathodyne circuit; Soviet 6F12P
triode-pentode.
The schematic is this: Click the image to open in full size.
I have built several amplifiers with this and the performance is very good.
Old 13th December 2012, 08:04 PM   #17
scott17 is offline scott17
I use this circuit. It has been well criticized. I know that DF96 has seen this before. It works very well for me.
Old 14th December 2012, 10:41 PM   #18
payitforwardeddie is offline payitforwardeddie  United Kingdom
Originally Posted by DF96 View Post
Mullard 5-20? The main snag with that is that it has too much gain for modern sources. The Lundahl site has a modified version.
That's what I'm building right now. Don't hold your breath though, I might have them finished by Christmas 2013.
Old 17th December 2012, 01:36 PM   #19
Tesla88's Avatar
I'm going to test the Williamson circuit , i've built a pratical test bench to try different configurations , like Dynaco ST70 with modern driver using 6922 tubes , or a combination of EF86 + 5814.
This evening i'll start with the Williamson , just to test Output trafo and power .
I Don't understand this , Output trasfo are rated for 35W rms , this is the nominal power of a EL34 UL configuration , size of OP trasformer core is same as a 200-250VA , really big and heavy.
Old 20th December 2012, 09:47 AM   #20
Tesla88's Avatar
Some test made with Williamson circuit using 6CG7 for input and driver, sounds great and output is around 40W rms (B+ 410V - 220mA at clip , ) , i get most 2nd harmonic distortion at medium levels . Bias is about 30mA each tube , el34 JJ
Output xformers are good sounding , really linear
I reduced the global NFB , getting more gain and more balanced sound , with original NFB i was getting a too "loudness" kind of sound.
Next step :
- substitute input tube with 5814
- try a triode cinfiguration for output tubes
Cheers
EL34 PushPull UL AmpHide this!Advertise here!
The Limitations of an EL34 in UL alexmoose Tubes / Valves 30 8th May 2010 12:40 PM
EL34 Pushpull imbalance fpelleti Tubes / Valves 10 23rd October 2008 05:04 PM
EL34 UL Curves draperphoto Tubes / Valves 8 29th September 2008 11:54 AM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
PSE UL EL84 or 6V6 or EL34? AudioGeek Tubes / Valves 6 9th March 2006 09:05 PM
