Old 10th December 2012, 11:13 PM   #1
Default Where to put the meter
Hello
I'm building an RH-84 with 6V6/6SL7 tubes.
I would like to monitor the current of each output stage.
Which place ( A B C D in red) would be the best to use?
Old 11th December 2012, 07:03 AM   #2
artosalo's Avatar
Do you mean quiescent current ?
During operation the average current is quite constant since 6V6 operates at class A.
This means that the A-meter reading stays almost in place.
I would use "B" and measure the voltage at this point.
Old 11th December 2012, 11:15 AM   #3
DUG is offline DUG  Canada
"I would use "B" and measure the voltage at this point. "
I agree
Doug We are all learning...we can all help
Old 11th December 2012, 01:16 PM   #4
Sorry, I did not make my question clear.
I want to mount 2 meters on the chassis and
monitor the current of each 6V6 at all times.
Old 11th December 2012, 04:10 PM   #5
artosalo's Avatar
These meters can be used to observe the quiescent current of both 6V6, but as I said, the reading do not vary according to the output power like happens with AB-class push-pull output stage.
Old 11th December 2012, 04:52 PM   #6
20to20 is offline 20to20  United States
20to20's Avatar
The maximum input voltage rating of the meter may be the deciding factor. If your B+ is higher than that you won't be able to use the tranny-side circuit.
Old 11th December 2012, 07:34 PM   #7
Thanks Artosalo.
Your point finally sunk in.
Old 11th December 2012, 08:27 PM   #8
oshifis is offline oshifis  Hungary
Here is my solution:
http://picasaweb.google.com/lcsaszar/807_amplifier
Old 11th December 2012, 09:58 PM   #9
20to20's Avatar
Originally Posted by brucetassin View Post
Thanks Artosalo.
The meters would look cool, though. And you would be monitoring an important tube/amp health factor.
Old 12th December 2012, 12:31 AM   #10
jjman is offline jjman  United States
If they are ammeters so they need to be in line with the current. I would cut the wire below the "5w" and wire them in there. This would include the screen as well as the plate current. Although the pcb makes that easier said than done.
A LED meter, Volt meter, power meter or light indicator... a nice gadget destroyer X Solid State 5 25th February 2011 06:30 PM
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
