Does anyone have a link to a 6H30 as a VA stage? I am working on an amp, and I have 184V on the plates with a 28.8K anode resistor, and 11.7V on the cathode. Just wondering what is "normal" for this tube. I have a 1.5K cathode resistor.
Thanks for any information! Blair |
#2 |
http://klausmobile.narod.ru/testerfiles/6n30p.htm
''Исток2''. Радиолампы - почтой. Параметры и характеристики 6Н30П-ДР классика Next-Tube. Справочные данные по лампам и трансформаторным сердечникам. http://www.tubes.ru/techinfo/HiFiAudio/6n30pdr.html http://www.tubeampdoctor.com/images/...ns%206N30P.pdf Google steers! Last edited by Charm; 10th December 2012 at 05:58 AM. |
#3 |
Thank you! I can find the tube data, but I wanted to see if anyone had a working schematic of this tube as the VA stage of their or a commercial amplifier. In my amp, I have: Using a 28.8K plate resistor and 1.5K cathode resistor: 184V on the plate, and 11.7V on my cathodes. I have never seen cathode voltage that high in a VA stage and wondered if it looked OK to run like this. Thank you! Blair |
#4 |
You are running 7.8mA for cathode current, which is well within the spec of the tube.
However, this is a low for best performance for this tube. Also your anode voltage is a too high. The two together will put you out of the most linear bias region. I would suggest decreasing your cathode resistor significantly, to increase anode current and lower anode voltage. |
#5 |
Thanks!
Looking at the tube specs, it looks like I need to also decrease the plate resistor from almost 30k to around 6-10K and change my dropping resistor in my PS to lower the plate voltage. You think 250-560 ohms for the cathode resistor? Ill tinker with it and post some voltages if you don't mind. Thanks again! Blair |
#6 |
pRC put some 6H30Pi experimentation up on his website. AudioVidioPhilia: Mambo Foreplay
#7 |
I tinkered with it a bit by changing the dropping resistor, plate and cathode resistor.
Now, I have a B+ of around 150V 72V on the plates, and 3.45V on the cathodes. Look better? Thanks? Blair |
#8 |
My suggestion.
#9 |
Is that for both sections in parallel?
#10 |
It was a single side. I ditched the 6H30. It acted very unstable and both that I have are fairly noisy. I had some wicked 120hz artifacts.
I swapped plate resistors, changed my cathode resistor, dropped a 6CG7 in and away went the noise and wobbly sine waves. I got the 6H30s from a buddy, so god knows what they went through. Thanks! |
| Large signal distortion in pre/VA stage | Thoru | Solid State | 9 | 10th June 2011 01:12 PM |
| looking for 6N6 and 6H30 | Gluca | Swap Meet | 0 | 9th May 2011 01:24 AM |
| Help modify 6H30 Mu-follower stage | RollE2k | Tubes / Valves | 22 | 11th February 2011 09:43 PM |
| Transformer VA versus output power VA | nigelwright7557 | Solid State | 8 | 18th May 2008 02:57 PM |
| 6H30 equivalents | woodturner-fran | Tubes / Valves | 7 | 20th October 2007 08:00 PM |
