Old 10th December 2012, 09:51 PM   #11
12B4A is online now 12B4A  United States
12B4A's Avatar
When I was using this tube I had to use little ferrite beads wrapped around the wires directly connected to the grid pins along with a 1k grid stopper before things settled down.
Old 10th December 2012, 11:00 PM   #12
Yeah,
It is probably very workable, but one was noticeable noisier than the other and the 6CG7 is very quiet. I'd be happy at this point with no more tweaks.
Thanks!
Blair
Old 12th December 2012, 05:52 PM   #13
rongon is offline rongon  United States
rongon's Avatar
Did you build anything like post #8. Yeah, 38mA, with a 3k plate resistor would be ok. That would keep the output impedance nice and low.
I think the reason your 6N30P was behaving badly was that it's running with such low plate current. I really think it sounds best with at least 15mA plate current, per triode section. That gets it out of the "knee" in the plate curves.
Old 12th December 2012, 06:17 PM   #14
Hi Ron,
Yes, regardless of how I swapped things according to various schematics for the tube, they were noticeably noisier than the 6CG7.
Old 12th December 2012, 06:19 PM   #15
rongon's Avatar
Did you try a different 6N30P tube? Or you only have that one?
Old 12th December 2012, 06:31 PM   #16
I have two, and one was worse than the other for noise. I really only used them because they were here. I'm not bent on using them really.
Old 12th December 2012, 06:42 PM   #17
rongon's Avatar
Well, that is surprising, because I've used quite a few of them and had completely the opposite experience. Just the basic Electro-Harmonix, normal ones you get for way too much money. All have been very well behaved. I guess it's just one of those crazy things.
Large signal distortion in pre/VA stage Thoru Solid State 9 10th June 2011 01:12 PM
looking for 6N6 and 6H30 Gluca Swap Meet 0 9th May 2011 01:24 AM
Help modify 6H30 Mu-follower stage RollE2k Tubes / Valves 22 11th February 2011 09:43 PM
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 02:57 PM
6H30 equivalents woodturner-fran Tubes / Valves 7 20th October 2007 08:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
