The Morgan Jones mini tube headphone Amplifier - Page 7 - diyAudio
Old 25th February 2013, 06:48 PM   #61
tomchr is online now tomchr  Canada
tomchr's Avatar
Rather than typing the component values into LTspice in ohm, farad, etc. I strongly suggest using prefixes. Just beware that any spice simulation is ignorant of common conventions and doesn't distinguish between lower and upper case letters for prefixes. Hence m or M is milli (m) = 1E-3 and Meg is used for M = 1E6.
It's a lot easier to read the schematic and avoid mistakes when a capacitance is listed as 220n rather than 0.00000022 (I hope I got the number of zeros right).
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 25th February 2013, 06:56 PM   #62
merlin el mago's Avatar
Thanks Tom, first of all I will try inpout stage LED and output stage with RC.
Old 25th February 2013, 07:16 PM   #63
Which is why, after only 50 years or so of drawing schematics with a pencil or pen I settled on using the explicit form. It's actually easier, when working with a simulation, to delete or add a zero than it is to move a k.
Old 25th February 2013, 08:19 PM   #64
How many current draws all stereo headphone amp?
Old 25th February 2013, 10:02 PM   #65
I read 50mA but it seems to much, someone can confirm or knows real power consuption?
Old 25th February 2013, 10:43 PM   #66
20.76mA~
Run the transient simulation, hover the cursor (current clamp icon) over the voltage source, look in the bottom left-hand corner of the window - (minus)10.3806mA (per channel).
To see the tube dissipation, run the DC operating point simulation (right click schematic, 'Edit Simulation Cmd./DC op pnt', click OK, right click schematic, 'Run'), close the OP window, hover the cursor (pointing hand icon) over the tube, read the dissipation in the lower left-hand corner of the window.
Old 26th February 2013, 07:04 AM   #67
Stixx is offline Stixx  Germany
Stixx's Avatar
50mA is the amount the psu has to be capable of... the actual consumption was something like 23mA in my build.
Old 26th February 2013, 11:31 AM   #68
Thanks guys I suspected was a lot less.
Old 26th February 2013, 06:24 PM   #69
What disappointment sounds much better my mu-follower.
Old 12th February 2015, 01:19 AM   #70
Originally Posted by Vincent77 View Post
For 300 ohm headphones, a 47µ film capacitor on the output does the job. Fc(-3dB)=11.3 Hz
I am reading through this trying to understand sizing the output capacitor. I understand how 11.3 Hz is calculated thought I don't know what an ideal Hz is, but if I use my phones at 18 ohm i calculate I need an 800 uf cap on the output. If I am changing the output cap, should I be concerned about changing the 0.47 uf cap also? If changing the 800 uf cap makes sense, I would like to just add two 400 uf caps in parallel instead of getting one large cap. The math shows it is the same capacitance, but I don't know if it really has a sonic effect. The same question if I keep the 470 uf cap, sub two 235 uf caps.
I am pretty new to this as you can tell. I wouldn't think I would need to change the 1000 and 2200 uf caps because they look like they are just filtering to ground, but I am not really sure. A good resource to get a quick understand of tube circuits would be great too.
Thanks, I am very new to this. I have already build a hybrid amp and wanted to see how different a tube amp is.
Calculating output impedance of Morgan-Jones headphone amp? plasmator Headphone Systems 0 23rd October 2012 08:25 PM
“Earmax / G3 / Morgan Jones / Cavalli” Headphone Amp Reissue with 6SN7 Steroids pingfloid Tubes / Valves 0 11th May 2012 07:50 AM
Help with Morgan Jones headphone amp trevorjn Headphone Systems 7 6th December 2009 10:52 PM
FS: PCB's for the Morgan Jones tube headamp Nisbeth Swap Meet 0 19th October 2004 07:43 PM
Morgan Jones tube amp and equalization Prune Tubes / Valves 4 13th May 2003 07:00 PM
Copyright ©1999-2017 diyAudio
