The Morgan Jones mini tube headphone Amplifier - Page 6 - diyAudio
Old 9th January 2013, 09:43 AM   #51
merlin el mago's Avatar
Thanks for sharing the pics, your headphone amp seems shine like a gem.
Old 24th February 2013, 06:20 PM   #52
Can I use 100R for R4, I'm using ECC88 in place of 6DJ8? I only have 120R of 1/4W can be enough?
Old 25th February 2013, 10:48 AM   #53
C3 can be 2000uF in place of 2200uF?
Old 25th February 2013, 11:31 AM   #54
Could I use LEDs in place of cathode RC?
Old 25th February 2013, 03:11 PM   #55
Stixx is offline Stixx  Germany
Stixx's Avatar
Should be okay, but better parallel two 220R 1/4W...
Yes, it can be as small as 470uF. 2200uF is calculated for a low frequency of under 1Hz or so (from the top of my head), so 470uF is good. Tip: use 2x220uF Oscon... a worthwhile improvement.
Yes, in the first stage. Don't know about using LED's in Cathode Followers...
Didn't I send you my schematic of the Morgan Jones with LED bias...?
Old 25th February 2013, 03:15 PM   #56
OK
Perfect I have BG 220uF 16V
Yes I see that you are using LEDs in the input tube but I have the same doubt like you to use it in the white cathode follower?
What about R7, somw people said 10K in place of 22K?
Old 25th February 2013, 05:39 PM   #57
Stixx's Avatar
What about R7, some people said 10K in place of 22K?
I guess this one only serves when no headphones are connected... in my build I was using 47K. Sonically not relevant for sure.
Old 25th February 2013, 05:42 PM   #58
Old 25th February 2013, 06:31 PM   #59
Here, download a copy of LTspice and have a play with these. Put the file 'dmtriode.inc' in the same directory (C:\Program Files\LTC\LTspiceIV) you put the 'MJ_6DJ8_optimized.asc' file in. Open the .asc file, right click on the schematic and select run. The simulation will run. Click on Vout to see the sinewave. Rightclick on the sinewave and select 'View\FFT' to see the FFT. You can substitute values or put in an LED and see the effect. Go 'View/Spice Error Log' (after running the Transient simulation) to see the THD. If you right click and select 'Edit Simulation Cmd.' you can simulate the AC (frequency) response or find the DC operating point.
Morgan_Jones_headamp_optimized.zip
Old 25th February 2013, 06:44 PM   #60
Amazing, thank you.
Calculating output impedance of Morgan-Jones headphone amp? plasmator Headphone Systems 0 23rd October 2012 08:25 PM
“Earmax / G3 / Morgan Jones / Cavalli” Headphone Amp Reissue with 6SN7 Steroids pingfloid Tubes / Valves 0 11th May 2012 07:50 AM
Help with Morgan Jones headphone amp trevorjn Headphone Systems 7 6th December 2009 10:52 PM
FS: PCB's for the Morgan Jones tube headamp Nisbeth Swap Meet 0 19th October 2004 07:43 PM
Morgan Jones tube amp and equalization Prune Tubes / Valves 4 13th May 2003 07:00 PM
Copyright ©1999-2017 diyAudio
