The Morgan Jones mini tube headphone Amplifier
Old 8th December 2012, 04:52 PM   #11
DF96 is offline DF96  England
After the pot would be better, between the slider and R1. The value would depend on how big you are prepared to go with the other electrolytics. The basic idea is that the input LF rolloff, set by the cap and R1, is higher in frequency (by a factor of 2-5?) than the output rolloff, set by C4 and your headphone resistance. Also the cathode decouplers.
You also want the White follower to work properly, so the input cap should be less than C2.
Old 8th December 2012, 05:05 PM   #12
merlin el mago is offline merlin el mago
merlin el mago's Avatar
0.22uF or 0.1uF can be enough? how to know the reduced value for output cap?
Old 8th December 2012, 05:10 PM   #13
CR first-order high pass filter. Use a calculator, or simply build the circuit as it is. Modding a circuit may require understanding and arithmetic.
Old 8th December 2012, 05:16 PM   #14
torrence is offline torrence  United States
torrence's Avatar
Originally Posted by jam View Post
First-order continuous-time implementation
Figure 1: A passive, analog, first-order high-pass filter, realized by an RC circuit
The simple first-order electronic high-pass filter shown in Figure 1 is implemented by placing an input voltage across the series combination of a capacitor and a resistor and using the voltage across the resistor as an output. The product of the resistance and capacitance (R×C) is the time constant (τ); it is inversely proportional to the cutoff frequency fc, that is,
where fc is in hertz, τ is in seconds, R is in ohms, and C is in farads.
The natural frequency is proportional to 1/(RC) which is radians/second. You need a factor of 2 pi to get this in units of Hertz. In other words, fc = 1/(2 pi RC).
Old 8th December 2012, 06:11 PM   #15
Using 220nF
fc= 1/(2 pi X 1000000 ohms X 0.00000022 farads) = 1/1.38 = 0.72Hz
Old 8th December 2012, 06:31 PM   #16
Yes, 0.22uF and 1M give LF rolloff at 0.72Hz. A smaller cap might be better.
Old 8th December 2012, 06:38 PM   #17
Vincent77 is offline Vincent77  Europe
Vincent77's Avatar
For 300 ohm headphones, a 47µ film capacitor on the output does the job. Fc(-3dB)=11.3 Hz
Old 8th December 2012, 06:47 PM   #18
Vincent77's Avatar
Originally Posted by Stixx View Post
Here you go...
But when you want my opinion you'd better spend the money on output transformers than trying to pass the audio signal through humongous film capacitors.
There is something I don't like about that schematic. You are using fixed (LED) bias without a CCS load and with a 1M grid resistor. You risk instability.
Old 8th December 2012, 06:57 PM   #19
47uF film cap as output gives me 112.88Hz not 11.3Hz
Old 8th December 2012, 07:05 PM   #20
47uF with 300 ohms is 11.29Hz
The Morgan Jones mini tube headphone AmplifierHide this!Advertise here!
Calculating output impedance of Morgan-Jones headphone amp? plasmator Headphone Systems 0 23rd October 2012 09:25 PM
“Earmax / G3 / Morgan Jones / Cavalli” Headphone Amp Reissue with 6SN7 Steroids pingfloid Tubes / Valves 0 11th May 2012 08:50 AM
Help with Morgan Jones headphone amp trevorjn Headphone Systems 7 6th December 2009 11:52 PM
FS: PCB's for the Morgan Jones tube headamp Nisbeth Swap Meet 0 19th October 2004 08:43 PM
Morgan Jones tube amp and equalization Prune Tubes / Valves 4 13th May 2003 08:00 PM
Copyright ©1999-2017 diyAudio
