Floating OPT oscilloscope measuraments - Page 3 - diyAudio
Old 4th January 2013, 10:40 PM   #21
Pano is offline Pano  United States
Pano's Avatar
Thanks for the update!
For me it would be worth the 1.5dB loss to have the grounded secondary. But I like a slow, sloping rolled-off response, anyway.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 8th January 2013, 09:53 PM   #22
rrrs is offline rrrs  United States
Hi, there is some “weirdness” I am founding out with this transformer; there seems to be pronounced rise in distortion from 2K up.
Here are THD measurements I did in ARTA, all at 1W into 5.7ohm load (this are measurements of actual amplifier, not just OPT):
40Hz – 0.4%
100Hz – 0.31%
1KHz – 0.31%
2KHz – 0.37%
4KHz – 0.55%
6KHz – 0.77%
8KHz – 0.98%
10KHz – 1.2%
12KHz – 1.33%
14KHz – 1.37%
16KHz – 1.34%
18KHz – 1.17%
Then I did vey same measurement with Chinese made transformers that came with amp originally and got higher distortion (around 0.7% at 1KHz), but it would remain pretty consistent with higher frequency (getting higher once you go below 200Hz).
Here are figures I got from Chinese 10K OPT, 1W into 5.7ohm load on 8 ohm tap:
40Hz – 1.03%
100Hz – 0.72%
1KHz – 0.63%
10KHz – 0.79%
Then, on 4 ohm tap, again 1W into 5.7ohm load:
40Hz – 0.74%
100Hz – 0.36%
1KHz – 0.23%
10KHz – 0.46%
Would anyone have idea why is Lundahl distortion is rising at higher frequency while; would this be the function on higher primary (20K vs 10K for Chinese OPT)?
Lundahl has higher inter-winding capacitance which makes it roll-off earlier at HF; but would this influence distortion?
Measuring floating voltages with oscilloscope akis Equipment & Tools 58 17th May 2012 12:40 PM
Floating Cascode Stee Solid State 1 14th February 2010 11:30 AM
Floating the heaters YoungFred Tubes / Valves 2 16th September 2006 10:59 AM
Floating voltages eeka chu Solid State 12 29th January 2004 03:57 PM
Floating voltages eeka chu Parts 2 27th January 2004 09:10 AM
Copyright 1999-2017 diyAudio
