Old 7th December 2012, 08:13 PM   #1
Question Channel voltage mismatch
i've recently finished s simple preamp based on 6N6P tube (6x4 LCLC rectifier). i really like the sound but a mystery (to me) appeared.
in breadboard version, both plate voltages were desired 160V (470 Ohm cathode resistors). in final wooden chassis i got reading from one channel 160v, but other only 75 or so. just before plate resistors they are both 280, which is right. one side of double triode glows a bit less as well. i checked cath resistance - both 470 ohm. i changed the tube - same result. i also tried to insert the tube cca 5x to get rid off some possible oxidation in the socket. hearing-wise there is just a subtle difference but i'd like to solve this.
thanks for any opinions in advance.
all the best,
misok
Old 7th December 2012, 08:21 PM   #2
DF96 is offline DF96  England
Cathode voltages? Missing grid resistor?
Old 7th December 2012, 08:25 PM   #3
cathode voltage is correct 6v on the 'ok' channel, on the wrong one is around 10.
there are no grid resistors, i use cowon player as a source and it worked fine (= equally and with good voltages) breadborarded. so my idea is to tune it as it is (hum wise) and then add a stepper attenuator that i have.
Old 7th December 2012, 08:43 PM   #4
So what is grounding the grids for bias purposes? You can't use a step attenuator unless you can guarantee that it is make-before-break and will not fail.
Old 7th December 2012, 09:05 PM   #5
TubeHead Johnny's Avatar
Do you have a schematic handy?
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz
Old 7th December 2012, 09:23 PM   #6
thanks ! i just soldered 100k resistors across both channels and the voltages are both right. i still don't get it since before there were no grid resistors and voltakes on plate/cath matched, but now they do again and i can sleep well. one side still glows a bit less but it has to be a matter of a certain tube. it sounds good now.
i used this (well known) schematic http://diyparadise.com/web/images/stories/yeo5687.gif but with a 6N6P double triode. it sounds great even before fine-tuning values of cathode components.
Old 7th December 2012, 09:51 PM   #7
Your breadboard version must have provided a conducting path for the grids, either deliberately (resistor) or accidentally (leakage).
UcD400 & SMPS400/67 voltage mismatch? AIS Class D 1 31st October 2009 07:30 PM
IFR513 headphone amp channel mismatch zebra100 Headphone Systems 1 20th May 2009 03:10 PM
Voltage rating of p-channel MOSFET Tahmid Power Supplies 7 3rd July 2008 08:10 AM
Heater voltage mismatch m6tt Tubes / Valves 16 19th September 2007 02:06 AM
High voltage (>60V) P-channel JFET? PanzerLord Solid State 15 11th December 2003 12:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
