6072A Line-Amp
6072A Line-Amp
Old 8th November 2003, 07:18 PM   #1
JDeV is offline JDeV  United Kingdom
Default 6072A Line-Amp
(Follow up on this - http://www.diyaudio.com/forums/showt...559#post242559 )
I just completed this one and got some final measurements and some questions. I used a nice solid Rhodesian Rose Wood for chassis with stainless steel top and copper cladding on inside. Alps Blue pot and Holco resistors. Input and output wires are some left overs from "Van Der Hull" and "Nordost" interconnects. Main trafo and separate heater PSU trafo are in separate box , connected with 8 core umbilical to pre-amp box. Still using mixed brand 6072's , but are very pleased with sound.
1) Except for lefthand 20H choke - still old one - all other chokes and trafos are new, but I still get low frequency oscillation on speakers when using 6072 with Mullard 5-20 - why? But no problem with SS amp
2) How can I fix this problem ?
Here is my voltages and other notes and some pics:
Old 8th November 2003, 07:20 PM   #2
Top:
Old 8th November 2003, 07:23 PM   #3
Inside:
Old 8th November 2003, 07:24 PM   #4
More inside:
Old 8th November 2003, 07:25 PM   #5
Rear - with 8 pin connector:
Old 8th November 2003, 09:57 PM   #6
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Do I read this correctly?
The preamp + Mullard amps goes into LF oscillation but the same preamp and SS amps works fine?
To my logic I'd then conclude something's wrong with the Mullard amp but obviusly you don't seems to think so...
Frank
Old 8th November 2003, 11:47 PM   #7
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Motorboating?
You'd be surprised, but at low levels many valve amplifiers have lower f-3dB points than their transistor counterparts. The problem you describe sounds like motorboating, but that seems unlikely in your pre-amplifier circuit, so what frequency (estimated) are we talking about? 1Hz-2Hz?. The only thing I can presently see that looks odd is that you are using raw HT to set the elevation of your heater voltage, rather than filtered HT. I can't see how this could cause motorboating, but it's definitely not a good idea...
Edit: I've just taken a closer look at your photographs, and although I'm delighted to see a variac lurking in the background for a gentle start-up, I'm not so happy with your layout. Why are those two signal valves so far apart, and why are their associated components so far away? Audio components belong on the valve bases. Power supply stuff belongs further away. I know you have DC heaters, but the twist and layout of your heater wiring is not good.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th November 2003, 08:57 AM   #8
Do I read this correctly? The preamp + Mullard amps goes into LF oscillation but the same preamp and SS amps works fine? To my logic I'd then conclude something's wrong with the Mullard amp but obviusly you don't seems to think so...
No, not that I don't think so, it is quit possible. I just don't understand why it happens and how to solve it. Because if I use SS preamp with Mullard, all behaves very well.
All audio related components are on valve bases (pic.2) , other stuff down in box (pic.1) is for DC heater supply. It is difficult to measure, but oscillation is between 1Hz and 5Hz. It varies all the time. The 2 signal valves are for left and right channel. I used both sides of 6072A / channel . Is it importand that L and R must also be very close together? The twist in wire is only to keep them together, not really for any other reason. I can untwist and use cable ties instead if it will be better.
(2 pics in 1)
Old 9th November 2003, 11:37 AM   #9
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Well, you should do the obvious first - have PS decoupling close to the valves; keep input and output wiring well separated; follow a sensible star-earthing scheme - have separate earths for PS and amp and join them in one point. Sorry if you've already done this - i really hate staring at photos.
Old 9th November 2003, 11:43 AM   #10
EC8010's Avatar
It's not important to keep channels close together per se, but it keeps the earth wiring to the common power supply under control.
Assuming you have access to an oscilloscope:
Is the oscillation leaving the pre-amplifier? (DC couple the oscilloscope)
Is the heater supply stable?
Is the HT supply stable? (AC couple the oscilloscope)
As analog_sa says power supply decoupling close to the valves and star earthing usually avoids most problems.
6072A Line-AmpHide this!Advertise here!
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 26th January 2009 11:44 PM
GE JAN 6072A Valves (Tubes) mozfet Swap Meet 1 2nd August 2008 02:34 PM
Line output as line input transformer? bambadoo Tubes / Valves 7 22nd January 2008 06:44 AM
6072A/12AY7 for an AKG C12 Microphone Puggie Tubes / Valves 4 8th March 2006 03:38 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
