6072A Line-Amp
6072A Line-Amp
Old 17th November 2003, 06:32 PM   #21
JDeV is offline JDeV  United Kingdom
Default Re: Far too much gain
Originally posted by EC8010
All you need is the cathode follower to buffer the volume control. To do that, you need to remove the first stage, and insert a 2k2 resistor between the cathode and the existing 100k cathode resistor, then take a 1M resistor from this junction to the grid. (And add a 1k grid-stopper to the cathode follower to prevent RF oscillation.) Finally, connect the grid to the volume control via a 10n 400V capacitor.
Just like this?
Old 17th November 2003, 06:47 PM   #22
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Very nearly. A grid-stopper goes directly onto the grid and before anything else, so if you move your 1M resistor along to connect at the junction of the 1k and the 10n, it will be correct.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 17th November 2003, 09:56 PM   #23
Now I am smiling
Changed circuit as suggested by EC8010, all problems solved. So I ended up with not an "Improved Audionote M7 Clone" - but still a very good sounding preamp (or rather just a buffer). It does the job and I like it. Thanx again to EC8010, Frank and all others for your advice and assistance. Much appreciated
Now what to build (try) next??
Final circuit:
Old 17th November 2003, 10:18 PM   #24
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
You can still improve on this one but it kind of proves what people like EC8010, Brett and myself have advocated for the past years...
Glad you like it.
Frank
Old 17th November 2003, 10:27 PM   #25
Last question:
The unused half of 6072, must I just leave all pins open , or should I ground them? Does it matter? Both heaters is still active.
Old 18th November 2003, 02:25 AM   #26
EC8010's Avatar
Default Glad you like it.
I'm impressed. You modified it pretty damn quick. If you were driving a transistor amplifier, I'd say, "parallel the two valves and halve the resistor values," but you're not, so I suspect you will get better quality by grounding all the second valve's electrodes and leaving the first valve as it is.
Old 18th November 2003, 09:16 AM   #27
DrG is offline DrG  South Africa
To me it always seems "wasteful" to use only half a tube. Why not use both halves of a single 6072, one for each channel?
Or use the remaining half as an active load for the follower? Your B+ is sufficient and all you'd really need to take into account is the max permissible V(hk)... requiring only an R-R network to float the filaments at an acceptable voltage - say +80v. Best to check the 6072 datasheet for V(hk) limits though...
Another possibility to try would be the so-called "White cascode" configuration. If memory serves the tubecad website has plenty lowdown on these and other configs...
Old 19th November 2003, 12:55 AM   #28
If not, why not ?
I am catching a like in these glass things and can only see it as a way to learn more and in the process maybe improving my sound system.
So looking at the attached pic. , how do I then calculate Ra and Rk? It IS the White Cathode Follower - just drawn a little bit other wise B+ can be reduced if needed.
Old 19th November 2003, 11:18 AM   #29
EC8010's Avatar
Your fixed bias White cathode follower injects power supply noise directly into the signal, which is not ideal. If you lose that potential divider but add a cathode bias resistor in series with the first cathode, you can take a 1M grid-leak resistor from the grid to its lower end, and this will reject power supply noise. The cathode bias resistor will be the same value for both valves. The anode resistor should be 1/gm for maximum output current.
Old 19th November 2003, 11:32 AM   #30
fdegrove's Avatar
Default SOMETHING LIKE THIS...
The formulas can be found here:
TUBECAD
And a pic of a working circuit never hurts:
Frank
6072A Line-AmpHide this!Advertise here!
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 26th January 2009 11:44 PM
GE JAN 6072A Valves (Tubes) mozfet Swap Meet 1 2nd August 2008 02:34 PM
Line output as line input transformer? bambadoo Tubes / Valves 7 22nd January 2008 06:44 AM
6072A/12AY7 for an AKG C12 Microphone Puggie Tubes / Valves 4 8th March 2006 03:38 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
