recognize this old amp? - Page 2 - diyAudio
Old 7th December 2012, 05:54 PM   #11
20to20 is offline 20to20  United States
20to20's Avatar
There is a circuit type that you could build on this chassis without adding a driver and socket. It's called a self-inverting push-pull, and you would rewire the existing inverter socket to take the driver tube and that's all you'd need. Apart from the gut job. Those output trannys look to be UL, too. On the bright side, you got your money's worth on the parts, if they're all good.
Old 7th December 2012, 06:47 PM   #12
trigger is offline trigger  United States
trigger's Avatar
what would be more simple, adding a driver tube or adding transistors for phase splitting?
ive got lots time and a lots of extra parts...
Old 7th December 2012, 06:58 PM   #13
Frank Berry's Avatar
I'm betting that this is an old Magnavox amplifier from a console stereo.
It's not a Zenith. Back then, Zenith copper-coated the inside of their chassis.
I once owned a Magnavox mono amplifier which was built on a very similar chassis.
It used a 5Y3, 12AX7 and a pair of 6V6 tubes.
This amplifier might be worth a rebuild before you dismantle the original amplifier and use the chassis to build another. The performance may surprise you!
Frank
Old 8th December 2012, 01:33 AM   #14
That depends, at least in part, on how well set up you are to do sheet metal work.
I'm no fan of BJTs, but FETs are a very different story. A FET is darned close to being a heaterless pentode. FETs work well in "unity" gain situations, like voltage followers and split load ("concertina") phase splitters. Enhancement mode "N" channel parts are extremely easy to DC couple to tube plates.
Let's say, for sake of argument, that a 12AX7 section will be the voltage amplifier. The FET to use is the ZVN0545A. Even the wimpy 'X7 triode has no problem in driving it's tiny capacitances.
Eli D.
anyone recognize this woofer? 60ndown Multi-Way 3 17th July 2012 01:20 AM
Anyone recognize these tweets??? Top Shelf Multi-Way 4 2nd June 2011 02:35 PM
Does someone recognize these? partner11 Multi-Way 1 6th August 2010 08:23 PM
anyone recognize this amp? damage Car Audio 22 17th January 2009 11:39 AM
Recognize this Transformer? Magnetmaz Parts 3 16th May 2003 03:16 AM
Copyright 1999-2017 diyAudio
