grey fogging inside 6sn7 - Page 2 - diyAudio
Old 9th December 2012, 03:23 PM   #11
kevinkr's Avatar
Those 6SN7 look very similar to a number of the older ones in my stash, I suspect they have been that way since the day they were produced. I've not ever had a problem with them either other than as previously remarked, and the ones I checked with the getter in this state were not gassy either.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th December 2012, 03:42 PM   #12
p.dow is offline p.dow  United States
Default hazey-foggy tube
on my tube (not pictured) the tube had previously not shown any such hazzieness as seen in those ebay tubes.... but a few weeks ago while causually using my equipment i noticed the appearance of it.
anyway just a note of futher interest.
not a expert but if buying a new tube i would shy away from one that looked like these. but maybe in the 50's things where different. nevertheless there are used 6sn7's that dont have this apperance.
thanks for reply.
paul
Old 9th December 2012, 04:00 PM   #13
kevinkr's Avatar
If that's the case then this particular tube may well have a problem, and I should mention that my comments apply only to the Sylvanias - I've not really seen any other brand (IIRC) that had getters that appeared this way.
I also have much later Sylvanias that generally do not have the fringe of white/grayish gettering.
6SN7/6SN7 Aikido + CS4398 DAC = HEAVEN john65b Tubes / Valves 23 30th April 2014 08:28 PM
Where to place amp: Inside a common cab or inside speakers? goldyrathore Chip Amps 3 3rd September 2010 01:39 PM
Grey noise angel Everything Else 7 12th August 2005 04:14 AM
Copyright 1999-2017 diyAudio
